Using x e y min pins for 3dTouch in a Fysetc E4
Posted by nacheitor
October 28, 2022 07:48AM
Hi, I'm using a Fysetc E4 board, and this board has too few pins to use. Since I use sensorless homing, the x and y min pins are free. How can I use these pins to for example connect the 3DTouch to the board?
I have defined the pin:
#define SERVO0_PIN 35 // SERVO
But when I try it, the 3d touch does not respond, it does not move the tip. Although in my configuration it is still defined:
#define Y_STOP_PIN 35
Because if I comment this line it doesn't compile. I've also tried commenting out the line:
#define USE_Y_PLUG
But there are also compilation errors.
So what is the correct way to disable y min so I can use it for the 3DTouch servo?
Thanks in advance.
Re: Using x e y min pins for 3dTouch in a Fysetc E4
October 28, 2022 10:15AM
Just taking Y as an Example, but X is the same
#define Y_STOP_PIN 35 means you only have 1 endstop pin on Y
If you home to min this is used as the Y-min endstop. If you home to max this used as the Y-max endstop
you need a Y endstop...
sensorless homing still uses this pin.
The Y diag pin is connected to Y_STOP_PIN via the jumper you install. this is how sersorless works
Ie X-Min and Y-Min is not free to use
Edited 3 time(s). Last edit at 10/28/2022 10:19AM by Dust.
October 28, 2022 11:18AM
Thanks for the info. Now I only have to try with the pin of the temperature of the bed.
October 28, 2022 11:54AM
temperature pins do not go directly to ths cpu, there is circuity in the way, they cannot be used.
See [github.com]
