No Display Output
November 12, 2022 02:06AM
I’ve been trying to install Marlin 2.x for the past few days on a Tronxy X1. Everything seems to be working on the printer correctly whenever it is plugged in and controlled by pronterface. However the display only ever turns on but never displays anything. I’ve tried using every lcd driver I thought would be appropriate on configuration.h. Have any of y’all had this same experience or possibly now a solution?
The printer has the Melzi board: CXY-V.2-0508 and a Reprap Discount Smart Controller.
Thanks in advance for any help.
open | download - 60867D2D-FE51-4C42-BCFF-13BA540387F8.jpeg (1.06 MB)
Re: No Display Output
November 12, 2022 02:48AM
That does not look like a Reprap Discount Smart Controller.
It seems to be a 128x64 mono graphics display from the shape and the outline of the pixels
Infact it looks just like this one
[www.tronxyglobal.com]
Even though they also say is a 2004 when it clearly says on the back of the pcb LCD-12864
Use REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Edited 4 time(s). Last edit at 11/12/2022 03:06AM by Dust.
November 12, 2022 04:38AM
Thank you for the quick reply.
I also tried that driver with and without the delays. For the delays I used [150,150,150] and [0,0,0] and nothing changed.
November 12, 2022 05:09AM
First issue
Its a Tronxy X1 Mini this comes with a 128x64 lcd with encoder
Not a Tronxy X1, which comes with a 20x4 lcd with 5 buttons
November 12, 2022 05:22AM
I’m still a beginner at installing a custom compiled version of Marlin on a printer, what issue does the encoder wheel create and how can I go about figuring out how to fix it?
The rest of the Marlin software works, it’s just the display and encoder that isn’t working.
