How can I move E steppers?
Posted by yello3d
January 11, 2023 01:03AM
How can I move the E axis steppers? I have like E0 to E3 steppers available.
But How can I move them with G code? (Pronterface)
G0 X50 moves the X axis.
But I don't know how to hove any of the E steppers.
And since they are mainly used for extruders, How can disable any cold filaments etc warning? (axis isn't used for filament)
Tried so far and not working:
G92 E0
G0 E10
Tried all "E" on X axis to make sure they work and all are working.
Re: How can I move E steppers?
January 11, 2023 01:15AM
You need to switch the active extruder.
Send to command Tx where x is the number of the tool/extruder you want to be active. The first extruder is 0.
If you have PARKING_EXTRUDER enabled then you can add S1 to the command to stop the parking sequence.
January 11, 2023 01:48AM
Also extruders have protection, they will refuse to move if hotend is not hot.
use
M302 P1 ; disable cold extrusion checking
And yes each extruder is a tool
T0
G1 E20 ; move current extruder 20mm
T1
G1 E20
T2
G1 E20
Edited 2 time(s). Last edit at 01/11/2023 01:58AM by Dust.
January 11, 2023 02:36AM
Thank you. For a starter I had to enable the steppers in Configuration.h (doh!)
#define E0_DRIVER_TYPE TMC2209
#define E1_DRIVER_TYPE TMC2209
#define E2_DRIVER_TYPE TMC2209
(Strangely Y and Z where still set to A4988, still working)
T0 works fine. But with T1 and T2 I get Invalid extruder
My (Marlin 2.1.x) Configuration_adv.h has no #if EXTRUDERS > 1
January 11, 2023 02:43AM
#define EXTRUDERS 1
Up this number
Just defining the stepper driver is not enough as you can have mixing extrudes...
Edited 1 time(s). Last edit at 01/11/2023 02:44AM by Dust.
January 11, 2023 02:48AM
code has
#if HAS_MULTI_EXTRUDER
January 11, 2023 03:00AM
Thank you, I changed to #define EXTRUDERS 3 - plus (0 gives me a firmware error for the other two):
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 1
#define TEMP_SENSOR_2 1
At this point everything works! in combination with M302 P1.
Thanks again!
Edited 2 time(s). Last edit at 01/11/2023 03:01AM by yello3d.
VDX
January 11, 2023 05:28AM
... for the extruders moving as you expect, you eventually have to switch between absolute and relative coordinates with "G90" and "G91" -- if absolute, then repeated "G0 E10" wont move after first occurance ...
Viktor
January 20, 2023 12:13AM
Sorry to bring that up again, is M302 P1 same as M302 S0 ?
It should also go in the startup, right? (Machine is not for 3D filament printing)
#define STARTUP_COMMANDS "M302 P1"
And how to define more than one #define STARTUP_COMMANDS "***"?
Edited 1 time(s). Last edit at 01/20/2023 12:58AM by yello3d.
January 20, 2023 08:52AM
Here's the docs for M302:
M302         ; report current cold extrusion state
M302 P0      ; enable cold extrusion checking
M302 S0      ; always allow extrusion (disables checking)
M302 S170    ; only allow extrusion above 170
M302 S170 P1 ; set min extrude temp to 170 but leave disabled
To add commands add a \n and then the second command.
