M404 - Changing Filament Diameter
Posted by AJS
AJS
February 06, 2023 10:09AM
Hi!
I have a very simple question, about filament diameter.
It´s strange why is needed two places, in configuration.h and in Slicer, but ok! I think!
Now I want change the filament diameter, I need to upload the firmware each time?
When I try use the command M404 the answer is: Unknown command!!?? How to enable it?
Any question or any sugestion are welcome!
ASousa
Re: M404 - Changing Filament Diameter
February 06, 2023 01:23PM
M404 is only enabled when FILAMENT_WIDTH_SENSOR is enabled.
Yes, changing DEFAULT_NOMINAL_FILAMENT_DIA will require compiling and re-flashing your controller.
AJS
February 06, 2023 02:00PM
Thank you Bob for your help.
I want to use the same printer for 2 types of filament, 3 and 1.75mm
In the last version of Marlin (2.1.2) I can´t find FILAMENT_WIDTH_SENSOR to enable it !?
I thought that it could be possible use a diameter as default with DEFAULT_NOMINAL_FILAMENT_DIA, and change the default with M404.
Thank you a lot!
February 06, 2023 05:29PM
FILAMENT_WIDTH_SENSOR can be found in configuration_adv.h
AJS
February 07, 2023 11:18AM
It´s working!
Thank you a lot.
AS
