My HOME is messy!
February 08, 2023 03:30AM
I have a messy HOME.
My HOME is at the back right side. Before it was at X0 Y0 - but with Pronterface the jog direction was wrong UP send Y to the front, LEFT send X right.
So I swapped X and Y direction:
#define INVERT_X_DIR true // was false
#define INVERT_Y_DIR true // was false
Not to have HOME now front left I also changed:
#define X_HOME_DIR 1 // was -1
#define Y_HOME_DIR 1 // was -1
Now it's homing correctly - but M114 gives me X415 Y415 instead of X0 Y0
A G0 X10 send X now to the other end.
How can I change that?
I am aware that after homing I can do G92 X0 Y0, from there X and Y move to Minus, so I wonder if that is the correct method.
Edited 1 time(s). Last edit at 02/08/2023 03:50AM by yello3d.
Re: My HOME is messy!
February 08, 2023 04:09AM
If you home to max, then the printer is at max position....
"A G0 X10 send X now to the other end." if it is in absolute position mode this is working as it should
"How can I change that?" you don't, its working normally
Printer have absolute and relative positions
G90 Absolute positioning
G91 Relative Positioning
when you home to max you set X and Y to max position
to move to x0,y0 you can either
G90
G1 X0 Y0
G91
G1 X-415 Y-415
Slicers use absolute position on X and Y, so prints will print fine
Edited 2 time(s). Last edit at 02/08/2023 04:13AM by Dust.
February 08, 2023 04:30AM
Mhm, after Homing to Max, can I tell the machine "this is Min now" ? I mean like telling Marlin direction is reversed now.
Means, I am at X0 Y0 but from here only can go positive....
Working in negative space is somehow confusing when working with min and max.
I mean, I like to have Pronterface jog in the correct direction, and work in a positive area.
Edited 1 time(s). Last edit at 02/08/2023 04:39AM by yello3d.
February 08, 2023 04:56AM
There is no negative space
print is from 0 to 415
If you home to max, then say that is 0, then your working iin negative space from -415 to 0
February 08, 2023 05:58AM
Ok, I don't want to be so negative.
I set HOME now to:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
That's in the front and sort of blocking working space. For homing purpose it's fine.
How could make it after homing go to i.e. X100 Y400 ?
G28
G0 X100 Y400 ; ?? (seems it's working)
