Get a random seed to randomize auto file order [C++, MarlinFW] March 04, 2023 06:01AM |
#if DISABLED(NO_SD_AUTOSTART)
Run all the auto#.g files. Called:
On boot after successful card init.
From the LCD command to Run Auto Files
void CardReader::autofile_begin() {
autofile_index = 1;
(void)autofile_check();
Run the next auto#.g file. Called:
After finishing the previous auto#.g file
From the LCD command to begin the auto#.g files
Return 'true' if an auto file was started
bool CardReader::autofile_check() {
if (!autofile_index) return false;
if (!isMounted())
mount();
else if (ENABLED(SDCARD_EEPROM_EMULATION))
settings.first_load();
// Don't run auto#.g when a PLR file exists
if (isMounted() && TERN1(POWER_LOSS_RECOVERY, !recovery.valid())) {
char autoname[10];
sprintf_P(autoname, PSTR("/auto%c.g"), '0' + autofile_index - 1);
if (fileExists(autoname)) {
cdroot();
openAndPrintFile(autoname);
// Generate a random number between 2 and 10
int randomNumber = random(2,10);
autofile_index = randomNumber;
return true;
autofile_cancel();
return false;
#endif`
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 04, 2023 04:27PM |
millis_t seed_32 = millis(); uint16_t seed_16 = seed_32 & 0xFFFF;
#include /* srand, rand */ /* initialize random seed: */ millis_t seed_32 = millis(); uint16_t seed_16 = seed_32 & 0xFFFF; srand (seed_16); #define M 2 // lowest number of desired range #define N 10 // highest number of desired range int randomNumber = M + rand() / (RAND_MAX / (N - M + 1) + 1);
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 05, 2023 11:06AM |
* Run all the auto#.g files. Called:
* - On boot after successful card init.
* - From the LCD command to Run Auto Files
autofile_index = 1;
* Run the next auto#.g file. Called:
* - After finishing the previous auto#.g file
* - From the LCD command to begin the auto#.g files
* Return 'true' if an auto file was started
if (!isMounted())
mount();
char autoname[10];
cdroot();
srand (seed_16);
return true;
autofile_cancel();
return false;
#endif
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 05, 2023 12:58PM |
#define seed_addr ????? uint16_t seed_16 = EEPROM_READ(seed_addr); srand (seed_16); seed_next = rand(); EEPROM_WRITE(seed_addr, seed_next); . . int randomNumber = M + seed_next / (RAND_MAX / (N - M + 1) + 1); // notice that rand() has been replaced by seed_next
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 06, 2023 02:14AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 07, 2023 03:34AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 07, 2023 08:15AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 07, 2023 02:47PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 09, 2023 02:21AM |
int randomNumber = 2;
In file included from Marlin\src\sd\random_auto_g_file_loader.cpp:51:
Marlin\src\sd\../feature/powerloss.h: In static member function 'static bool PrintJobRecovery::exists()':
Marlin\src\sd\../feature/powerloss.h:178:40: error: 'class CardReader' has no member named 'jobRecoverFileExists'
178 | static bool exists() { return card.jobRecoverFileExists(); }
Marlin\src\sd\../feature/powerloss.h: In static member function 'static void PrintJobRecovery
pen(bool)':
Marlin\src\sd\../feature/powerloss.h:179:46: error: 'class CardReader' has no member named 'openJobRecoveryFile'
179 | static void open(const bool read) { card.openJobRecoveryFile(read); }
In file included from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/WString.h:29,
from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/Print.h:27,
from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/Stream.h:26,
from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/HardwareSerial.h:29,
from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/WSerial.h:5,
from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/wiring.h:47,
from C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/Arduino.h:36,
from Marlin\src\sd\../module/../inc/../HAL/./STM32/../shared/Marduino.h:36,
from Marlin\src\sd\../module/../inc/../HAL/./STM32/HAL.h:28,
from Marlin\src\sd\../module/../inc/../HAL/HAL.h:30,
from Marlin\src\sd\../module/../inc/MarlinConfig.h:31,
from Marlin\src\sd\../module/motion.h:31,
from Marlin\src\sd\random_auto_g_file_loader.cpp:48:
Marlin\src\sd\random_auto_g_file_loader.cpp: In function 'bool random_auto_g_file_loader()':
Marlin\src\sd\random_auto_g_file_loader.cpp:127:51: error: 'utostr3' was not declared in this scope; did you mean 'ftostr3'?
127 | sprintf_P(autoname, PSTR("AUTO%s.g"), utostr3(randomNumber));
C:\Users\danin\.platformio\packages\framework-arduinoststm32\cores\arduino/avr/pgmspace.h:71:40: note: in definition of macro 'sprintf_P'
71 | #define sprintf_P(s, ...) sprintf((s), __VA_ARGS__)
Marlin\src\sd\random_auto_g_file_loader.cpp: In function 'uint8_t get_max_autofile()':
Marlin\src\sd\random_auto_g_file_loader.cpp:160:45: error: 'utostr3' was not declared in this scope; did you mean 'ftostr3'?
160 | sprintf_P(autoname, PSTR("AUTO%s.g"), utostr3(counter));
*** [.pio\build\STM32F103RC_btt\src\src\sd\random_auto_g_file_loader.cpp.o] Error 1
Marlin\src\sd\cardreader.cpp: In static member function 'static bool CardReader::autofile_check()':
Marlin\src\sd\cardreader.cpp:853:26: error: 'randomNumber' was not declared in this scope
853 | autofile_index = randomNumber;
*** [.pio\build\STM32F103RC_btt\src\src\sd\cardreader.cpp.o] Error 1
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 09, 2023 12:50PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 10, 2023 02:34AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 10, 2023 12:16PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 16, 2023 02:47PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 16, 2023 04:08PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 17, 2023 03:11AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 17, 2023 01:53PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 19, 2023 10:19AM |
echo:Now fresh file: seed.txt Writing to file: seed.txt echo:Now fresh file: AUTO3.g File opened: AUTO3.g Size: 1343625 File selected Exception in thread read thread: Traceback (most recent call last): File "printrun\printcore.py", line 333, in _readline File "printrun\printcore.py", line 329, in _readline_nb File "serial\serialwin32.py", line 275, in read serial.serialutil.SerialException: ClearCommError failed (PermissionError(13, 'The device does not recognizes the command.', None, 22)) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "threading.py", line 932, in _bootstrap_inner File "threading.py", line 870, in run File "printrun\printcore.py", line 418, in _listen File "printrun\printcore.py", line 387, in _listen_until_online File "printrun\printcore.py", line 354, in _readline IndexError: tuple index out of range
Re: Get a random seed to randomize auto file order [C++, MarlinFW] March 19, 2023 03:32PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] April 21, 2023 09:20AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] April 21, 2023 10:11AM |
Admin Registered: 15 years ago Posts: 7,304 |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] April 23, 2023 12:56PM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] April 24, 2023 01:40AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] April 24, 2023 10:55AM |
Re: Get a random seed to randomize auto file order [C++, MarlinFW] June 30, 2025 10:40PM |
