G28 X does not home the X axis March 08, 2023 11:34AM |
Re: G28 X does not home the X axis March 08, 2023 05:31PM |
Re: G28 X does not home the X axis March 08, 2023 06:03PM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: G28 X does not home the X axis March 08, 2023 09:29PM |
VDX
... could be, your endstops are already "triggered", so the movement is trying to leave the endswitch, but because it didn't change, stops and gives an internal error.
Check the status of the endswitches with "M119" ...
Re: G28 X does not home the X axis March 08, 2023 09:32PM |
[email protected]
When you send G0 X commands, does the head move in the correct direction the correct distance?
Does the X stepper buzz a lot when this happens? If yes then you may be marginal on your stepper settings. If the acceleration and/or feedrate are too high then the stepper motor functionality can be pretty bizarre. It can just sit there and buzz or move in jerks or move the wrong way. Try dropping the feedrates and acceleration settings by half. Don't forget the homing feedrates.
