Compilazione Marlin bloccata
October 31, 2023 05:15AM
Salve a tutti sono nuovo in questo forum e ho un problema con la compilazione del firmware marlin 2.1.2 su una scheda robin nano v1.2. Non ho trovato nulla in rete al riguardo e spero nella vostro aiuto. Ho una sapphire plus e sto cercando di fare un firmware personalizzato per implementare l'input shaping. Ma nella compilazione con Visual studio code con autobuild marlin resta fermo alla dicitura marlinserial.cpp.o
Re: Compilazione Marlin bloccata
October 31, 2023 05:23AM
Please post actual full error messages and attach the Config files your using.
October 31, 2023 05:44AM
Marlin has example configs for this printer
[github.com]
Which builds fine
Advanced Memory Usage is available via "PlatformIO Home > Project Inspect"
RAM:   [==========]  95.3% (used 62448 bytes from 65536 bytes)
Flash: [=====     ]  50.1% (used 262516 bytes from 524288 bytes)
Building .pio/build/mks_robin_nano_v1v2/firmware.bin
encrypt([".pio/build/mks_robin_nano_v1v2/firmware.bin"], [".pio/build/mks_robin_nano_v1v2/firmware.elf"])
======================================================= [SUCCESS] Took 24.44 seconds =======================================================
Environment          Status    Duration
mks_robin_nano_v1v2  SUCCESS   00:00:24.443
======================================================== 1 succeeded in 00:00:24.443 ========================================================
But note: this controller only has 65536 ram and marlin is already using 62448 95% of it. (exceeding 95% is not advisable, and normally results in random crashes and reboots)
Input shaping needs ram..
You cannot enable input shaping on this controller without turning off other things or reducing memory usage.
59.5% of memory is being used by your MKS_ROBIN_TFT35 display
// 480x320, 3.5", FSMC Display From MKS
// Usually paired with MKS Robin Nano V1.2
you could reduce the screen buffer screen Marlin/src/pins/stm32f1/pins_MKS_ROBIN_NANO_common.h
#define TFT_BUFFER_SIZE 14400
to #define TFT_BUFFER_SIZE 12000
that would free up 7% of your ram for input shaping, but will slow down screen updates slightly.
Edited 3 time(s). Last edit at 10/31/2023 06:04AM by Dust.
October 31, 2023 07:12AM
Vi ringrazio per le dritte...appena torno a casa provo...allegheró al più presto i file di configurazione.
October 31, 2023 08:46AM
ho allegato i file e anche con la configurazione base mi resta in quella schermata...
open | download - Immagine 2023-10-31 134232.png (170.6 KB)
open | download - Configuration.h (125.7 KB)
open | download - Configuration_adv.h (173.4 KB)
October 31, 2023 09:12AM
anche quando faccio inspect platformio mi resta fermo li. non capisco cos'è che non va.
open | download - Immagine 2023-10-31 141028.png (112.7 KB)
November 01, 2023 12:08AM
Cannot reproduce
Using your config files
Compiling .pio/build/mks_robin_nano_v1v2/src/src/HAL/STM32/MarlinSerial.cpp.o
Compiling .pio/build/mks_robin_nano_v1v2/src/src/HAL/STM32/MinSerial.cpp.o
Compiling .pio/build/mks_robin_nano_v1v2/src/src/HAL/STM32/Servo.cpp.o
Compiling .pio/build/mks_robin_nano_v1v2/src/src/HAL/STM32/eeprom_bl24cxx.cpp.o
Compiling .pio/build/mks_robin_nano_v1v2/src/src/HAL/STM32/eeprom_flash.cpp.o
Linking .pio/build/mks_robin_nano_v1v2/firmware.elf
Checking size .pio/build/mks_robin_nano_v1v2/firmware.elf
Flash: [=====     ]  50.1% (used 262876 bytes from 524288 bytes)
no issues building
Inspect also worked, but did take a very long time
Edited 2 time(s). Last edit at 11/01/2023 01:06AM by Dust.
November 02, 2023 05:26AM
continua a darmi questo:
PS C:\Users\utente\Downloads\Marlin-2.1.2.1> platformio run -e mks_robin_nano_v1v2
Processing mks_robin_nano_v1v2 (board: genericSTM32F103VE; platform: ststm32@~12.1; framework: arduino)
-------------------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing platformio/toolchain-gccarmnoneeabi @ ~1.90201.0
Downloading [####################################] 100%
Unpacking [####################################] 100%
Tool Manager: toolchain-gccarmnoneeabi@1.90201.191206 has been installed!
Tool Manager: Installing platformio/framework-cmsis @ ~2.50501.0
Tool Manager: framework-cmsis@2.50501.200527 has been installed!
Tool Manager: Installing platformio/framework-arduinoststm32 @ ~4.10900.0
Tool Manager: framework-arduinoststm32@4.10900.200819 has been installed!
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: [docs.platformio.org]
PLATFORM: ST STM32 (12.1.1) > STM32F103VE (64k RAM. 512k Flash)
HARDWARE: STM32F103VET6 72MHz, 64KB RAM, 512KB Flash
DEBUG: Current (stlink) External (blackmagic, cmsis-dap, jlink, stlink)
PACKAGES:
- framework-arduinoststm32 @ 4.10900.200819 (1.9.0)
- framework-cmsis @ 2.50501.200527 (5.5.1)
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Converting Marlin.ino
LDF: Library Dependency Finder -> [bit.ly]
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 10 compatible libraries
Scanning dependencies...
Dependency Graph
|-- IWatchdog @ 1.0.0
|-- SPI @ 1.0
|-- EEPROM @ 2.0.1
|-- SoftwareSerial @ 1.0
|-- Wire @ 1.0
|-- Servo @ 1.1.2
Building in release mode
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduinoVariant\PeripheralPins.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduinoVariant\variant.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\HardwareTimer.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\Print.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\RingBuffer.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\USBSerial.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\VirtIOSerial.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\WInterrupts.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\WSerial.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\WString.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\abi.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\avr\dtostrf.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\board.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\hooks.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\itoa.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\main.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\new.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\pins_arduino.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\device.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\condition.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\cortexm\sys.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_device.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_init.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_io.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\generic_shmem.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\generic\time.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\init.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\io.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\log.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\libmetal\shmem.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\mbox_ipcc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\open-amp\remoteproc\remoteproc_virtio.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\open-amp\rpmsg\rpmsg.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\open-amp\rpmsg\rpmsg_virtio.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\openamp.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\rsc_table.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\virt_uart.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\virtio\virtio.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\virtio\virtqueue.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\virtio_buffer.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\OpenAMP\virtio_log.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\startup_stm32yyxx.S.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\cdc\cdc_queue.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\cdc\usbd_cdc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\cdc\usbd_cdc_if.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\hid\usbd_hid_composite.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\hid\usbd_hid_composite_if.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usb_device_core.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usb_device_ctlreq.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usb_device_ioreq.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usbd_conf.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usbd_desc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usbd_ep_conf.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\stm32\usb\usbd_if.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\wiring_pulse.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\wiring_shift.c.o
Compiling .pio\build\mks_robin_nano_v1v2\FrameworkArduino\wiring_time.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_adc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_adc_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_can.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_cec.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_comp.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_comp_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_cordic.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_cortex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_crc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_crc_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_cryp.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_cryp_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dac.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dac_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dma.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dma2d.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dma_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dsi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_dts.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_eth.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_eth_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_exti.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_fdcan.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_firewall.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_flash.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ramfunc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_fmac.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_gfxmmu.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_gpio.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_gpio_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_hash.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_hash_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_hcd.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_hrtim.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_hsem.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_i2c.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_i2c_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_i2s.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_i2s_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_ipcc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_irda.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_iwdg.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_jpeg.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_lcd.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_lptim.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_ltdc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_ltdc_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_mdios.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_mdma.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_mmc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_mmc_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_nand.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_nor.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_opamp.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_opamp_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_ospi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_otfdec.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pccard.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pcd.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pcd_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pka.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pssi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pwr.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_pwr_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_qspi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_ramecc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_rcc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_rcc_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_rng.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_rng_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_rtc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_rtc_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sai.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sai_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sd.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sd_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sdadc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sdram.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_smartcard.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_smartcard_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_smbus.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_spdifrx.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_spi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_spi_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_sram.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_swpmi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_tim.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_tim_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_tsc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_uart.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_uart_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_usart.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_usart_ex.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\HAL\stm32yyxx_hal_wwdg.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_adc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_bdma.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_comp.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_cordic.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_crc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_crs.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_dac.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_delayblock.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_dma.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_dma2d.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_exti.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_fmac.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_fmc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_fsmc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_gpio.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_hrtim.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_i2c.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_lptim.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_lpuart.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_mdma.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_opamp.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_pka.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_pwr.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_rcc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_rng.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_rtc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_sdmmc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_spi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_swpmi.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_tim.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_ucpd.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_usart.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_usb.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\LL\stm32yyxx_ll_utils.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\PortNames.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\analog.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\bootloader.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\clock.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\core_callback.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\dwt.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\hw_config.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\interrupt.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\lock_resource.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\low_power.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\pinmap.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\rtc.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\stm32_def.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\stm32_eeprom.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\system_stm32yyxx.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\timer.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\stm32\uart.c.o
Compiling .pio\build\mks_robin_nano_v1v2\SrcWrapper\src\syscalls.c.o
Compiling .pio\build\mks_robin_nano_v1v2\src\src\HAL\STM32\HAL.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\src\src\HAL\STM32\HAL_SPI.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\src\src\HAL\STM32\MarlinSPI.cpp.o
Compiling .pio\build\mks_robin_nano_v1v2\src\src\HAL\STM32\MarlinSerial.cpp.o
e qui si ferma.
November 02, 2023 11:13AM
Download malwarebytes and scan your system for malware (just to be sure)
Then delete C:\Users\utente\.platformio and restart vscode, this will reinstall all platformio from scratch
And try again.
Edited 1 time(s). Last edit at 11/02/2023 11:13AM by Dust.
November 04, 2023 12:05PM
Ho appena risolto facendo così. Grazie a tutti per l'aiuto.
November 23, 2023 05:48AM
Come individuare e selezionare le discipline sportive più promettenti per le scommesse. Le scommesse mirate nei contesti sportivi ideali. Una guida completa alle puntate e agli eventi sportivi. Navigare nel vasto mondo delle scommesse sportive può risultare complesso https://www.sassilive.it/economia/lavoro/i-migliori-sport-su-cui-scommettere/, poiché non è sempre semplice identificare quali siano i migliori sport su cui scommettere. Attualmente, la gamma di eventi sportivi disponibili per le puntate è così ampia da rendere l'identificazione della scelta più intrigante una vera e propria impresa titanica. Oggi cerchiamo di offrire chiarezza su questo tema, fornendo informazioni fondamentali per effettuare scelte ponderate.
Edited 1 time(s). Last edit at 11/24/2023 05:10AM by besteonlinecasinoschweiz.
May 11, 2024 03:16PM
Cicciostampa
ciao sto cercando pure io di fare un firmware con Input Shaping
per la mia SP5 con doppio motore in Z
avresti modo di condividere il firmware che hai fatto
grazie mille
