ABL Slow Probe fail! - No trigger
Posted by tfinny
May 13, 2024 04:03PM
I'm hoping someone here can help me. I'm having trouble with ABL on my homemade printer. I'm able to home the x/y/z axes with no problem but when I send the g29 command it fails on the first point. I'm using a fixed probe proximity switch and an skr 1.4 turbo.
Thanks
14:01:33.941 : No start signal detected - forcing start
14:01:33.957 : N1 M110*34
14:01:33.957 : N2 M115*36
14:01:33.957 : N3 M105*36
14:01:33.957 : N4 M114*35
14:01:33.957 : FIRMWARE_NAME:Marlin 2.1.2.2 (May 12 2024 23:13:55) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:3D Printer EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
14:01:33.957 : N5 M220 S100*100
14:01:33.957 : N6 M221 S100*102
14:01:33.957 : N7 M111 S6*96
14:01:33.957 : Capconfused smileyERIAL_XON_XOFF:0
14:01:33.957 : Cap:BINARY_FILE_TRANSFER:0
14:01:33.957 : Cap:EEPROM:1
14:01:33.957 : Cap:VOLUMETRIC:1
14:01:33.957 : Cap:AUTOREPORT_POS:0
14:01:33.957 : N8 T0*50
14:01:33.957 : Cap:AUTOREPORT_TEMP:1
14:01:33.957 : N9 M20*24
14:01:33.957 : Captongue sticking out smileyROGRESS:0
14:01:33.957 : Captongue sticking out smileyRINT_JOB:1
14:01:33.957 : Cap:AUTOLEVEL:1
14:01:33.957 : Cap:RUNOUT:0
14:01:33.957 : Cap:Z_PROBE:1
14:01:33.957 : Cap:LEVELING_DATA:1
14:01:33.957 : Cap:BUILD_PERCENT:0
14:01:33.957 : Capconfused smileyOFTWARE_POWER:0
14:01:33.957 : Cap:TOGGLE_LIGHTS:0
14:01:33.957 : Cap:CASE_LIGHT_BRIGHTNESS:0
14:01:33.957 : Cap:EMERGENCY_PARSER:0
14:01:33.957 : Cap:HOST_ACTION_COMMANDS:0
14:01:33.957 : Captongue sticking out smileyROMPT_SUPPORT:0
14:01:33.957 : Capconfused smileyDCARD:0
14:01:33.957 : Cap:REPEAT:0
14:01:33.957 : Capconfused smileyD_WRITE:0
14:01:33.957 : N10 M80*42
14:01:33.957 : Cap:AUTOREPORT_SD_STATUS:0
14:01:33.957 : Cap:LONG_FILENAME:0
14:01:33.957 : Cap:LFN_WRITE:0
14:01:33.957 : Cap:CUSTOM_FIRMWARE_UPLOAD:0
14:01:33.957 : Cap:EXTENDED_M20:0
14:01:33.957 : Cap:THERMAL_PROTECTION:1
14:01:33.957 : Cap:MOTION_MODES:0
14:01:33.957 : Cap:ARCS:1
14:01:33.957 : Cap:BABYSTEPPING:1
14:01:33.957 : Cap:CHAMBER_TEMPERATURE:0
14:01:33.957 : Cap:COOLER_TEMPERATURE:0
14:01:33.957 : Cap:MEATPACK:0
14:01:33.957 : Cap:CONFIG_EXPORT:0
14:01:33.957 : N11 M105*23
14:01:33.957 : N12 M111 S6*84
14:01:33.957 : X:43.30 Y:6.00 Z:-2.00 E:0.00 Count X:3464 Y:480 Z:-8000
14:01:33.957 : echogrinning smileyEBUG:INFO,ERRORS
14:01:33.957 : echo:Unknown command: "M20"
14:01:33.957 : echo:Unknown command: "M80"
14:01:33.957 : N13 T0*8
14:01:33.957 : N14 M155 S1*85
14:01:45.121 : N15 G28*39
14:02:03.044 : X:100.00 Y:100.00 Z:0.00 E:0.00 Count X:8000 Y:8000 Z:0
14:02:39.486 : N16 M111 S32*103
14:02:39.486 : echogrinning smileyEBUGgrinning smileyETAIL
14:02:45.147 : N17 G29*36
14:02:45.147 : >>> G29  X100.00 Y100.00 Z0.00
14:02:45.147 : Machine Type: Cartesian
14:02:45.147 : Probe: FIX_MOUNTED_PROBE
14:02:45.147 : Probe Offset X-33.30 Y4.00 Z0.00 (Left-Back & Same Z as Nozzle)
14:02:45.147 : Auto Bed Leveling: BILINEAR (disabled)
14:02:45.147 : >>> set_bed_leveling_enabled  X100.00 Y100.00 Z0.00
14:02:45.147 : <<< set_bed_leveling_enabled  X100.00 Y100.00 Z0.00
14:02:45.147 : current_position= X100.00 Y100.00 Z0.00 : Probe::set_deployed
14:02:45.147 : deploy: 1
14:02:45.147 : Probe::do_z_raise(5.00)
14:02:45.147 : do_blocking_move_to_z(5.00, 4.00)
14:02:45.147 : >>> do_blocking_move_to  X100.00 Y100.00 Z0.00
14:02:45.147 : >  X100.00 Y100.00 Z5.00
14:02:47.483 : <<< do_blocking_move_to  X100.00 Y100.00 Z5.00
14:02:47.483 : >>> do_blocking_move_to  X100.00 Y100.00 Z5.00
14:02:47.483 : >  X100.00 Y100.00 Z5.00
14:02:47.483 : reset_bed_level
14:02:47.483 : >>> set_bed_leveling_enabled  X100.00 Y100.00 Z5.00
14:02:47.483 : <<< set_bed_leveling_enabled  X100.00 Y100.00 Z5.00
14:02:47.483 : >>> Probe::probe_at_point  X100.00 Y100.00 Z5.00
14:02:47.483 : ...(10.00, 10.00, raise, 0, probe_relative)
14:02:47.483 : current_position= X100.00 Y100.00 Z5.00 :
14:02:47.483 : >  X43.30 Y6.00 Z5.00
14:02:48.658 : <<< do_blocking_move_to  X43.30 Y6.00 Z5.00
14:02:48.658 : current_position= X43.30 Y6.00 Z5.00 : Probe::set_deployed
14:02:48.658 : deploy: 1
14:02:48.658 : >>> Probe::run_z_probe  X43.30 Y6.00 Z5.00
14:02:48.658 : >>> Probe::probe_down_to_z  X43.30 Y6.00 Z5.00
14:02:48.658 : do_blocking_move_to_z(-2.00, 2.00)
14:02:48.658 : >>> do_blocking_move_to  X43.30 Y6.00 Z5.00
14:02:48.658 : >  X43.30 Y6.00 Z-2.00
14:02:52.627 : <<< do_blocking_move_to  X43.30 Y6.00 Z-2.00
14:02:52.627 : current_position= X43.30 Y6.00 Z-2.00 : sync_plan_position
14:02:52.627 : <<< Probe::probe_down_to_z  X43.30 Y6.00 Z-2.00
14:02:52.627 : SLOW Probe fail! - No trigger.
14:02:52.627 : <<< Probe::run_z_probe  X43.30 Y6.00 Z-2.00
14:02:52.627 : current_position= X43.30 Y6.00 Z-2.00 : Probe::set_deployed
14:02:52.627 : deploy: 0
14:02:52.627 : >>> do_blocking_move_to  X43.30 Y6.00 Z-2.00
14:02:52.627 : >  X43.30 Y6.00 Z-2.00
14:02:52.627 : Errortongue sticking out smileyrobing Failed
14:02:52.627 : measured_z: 0.00
14:02:52.627 : <<< Probe::probe_at_point  X43.30 Y6.00 Z-2.00
14:02:52.627 : >>> set_bed_leveling_enabled  X43.30 Y6.00 Z-2.00
14:02:52.627 : <<< set_bed_leveling_enabled  X43.30 Y6.00 Z-2.00
14:02:52.627 : current_position= X43.30 Y6.00 Z-2.00 : > probing complete
14:02:52.627 : >>> move_z_after_probing  X43.30 Y6.00 Z-2.00
14:02:52.627 : <<< move_z_after_probing  X43.30 Y6.00 Z-2.00
14:02:52.627 : X:43.30 Y:6.00 Z:-2.00 E:0.00 Count X:3464 Y:480 Z:-8000
14:02:52.627 : <<< G29  X43.30 Y6.00 Z-2.00
Edited 1 time(s). Last edit at 05/13/2024 11:48PM by tfinny.
