Hello, dear people,
I am currently trying to use the unused port HotEnd 2 (Heater2) for lighting purposes.
According to the existing circuit diagram of the board, the power amplifier for H2 is connected to CPU pin 7 (PE5, PWM2).
But that can't actually be the case, because in
pins_GT2560_REV_A.h (included by
pins GT2560 REV_A_PLUS.h), PIN7 is intended for fan0 and H2 is supposedly connected to PIN3.
I have now commented out
#define HEATER_1_PIN 3 in
pins_GT2560_REV_A.h and set
#define CASE_LIGHT_PIN 3 in
Configuration_adv.h.
It don't crash when compiling, but it doesn't work either...
Do I have the wrong circuit diagram of the board here? It seems so...
But even if... In the pinning for the board, PIN3 is originally set for the second HotEnd; so it should work...
What am I missing here?
EDIT:
Crazy
... Light goes on if I set P to 255 / 100% and goes off at 99% / less then 255. but Heater2 is also a PWM like Heater1...
Edited 1 time(s). Last edit at 05/28/2024 11:42AM by CBX.Micha.
DLzG...
Micha
