SKR 1.3 Bed Enable Pin (Extra failsafe for the failsafe)
Posted by ngen33r
June 18, 2024 09:28PM
I know this has been mentioned a few times, but there has not been an answer. I have 2 seperate issues that I am struggling with.
1. I cannot seem to get the IO pins to respond to M42 despite having it enabled in firmware. I have tried a couple pins and the diag screen does not let me swap them to Output or change the state and these are not protected pins.
2. I want to add an extra fail-safe into the firmware for Bed Enable. I am using a 120V bed that is fused, fed through a relay to an SSR with a thermal switch in series. I have worked with thermal switches on industrial equipment and they too can fail to open, although rare, it can happen and I have seen it happen. Yes I could run 2 of them in series, but I have a relay that I want to use that is opto-isolated and will keep the power off to the bed at all times unless a print is happenning. I have looked at the code, but I am not well versed in C++. I would like to add the enable trigger in the start and stop heat bed code and also add it to the kill code.
For the KILL code it seems like it could go in several places, not sure what one.
void Temperature::_temp_error(const heater_id_t heater_id, FSTR_P const serial_msg, FSTR_P const lcd_msg) {
  static uint8_t killed = 0;
  if (IsRunning() && TERN1(BOGUS_TEMPERATURE_GRACE_PERIOD, killed == 2)) {
    SERIAL_ERROR_START();
    SERIAL_ECHOF(serial_msg);
    SERIAL_ECHOPGM(STR_STOPPED_HEATER);
    heater_id_t real_heater_id = heater_id;
    #if HAS_TEMP_REDUNDANT
      if (heater_id == H_REDUNDANT) {
        SERIAL_ECHOPGM(STR_REDUNDANT); // print redundant and cascade to print target, too.
        real_heater_id = (heater_id_t)HEATER_ID(TEMP_SENSOR_REDUNDANT_TARGET);
    #endif
    switch (real_heater_id) {
      OPTCODE(HAS_TEMP_COOLER,  case H_COOLER:  SERIAL_ECHOPGM(STR_COOLER);         break)
      OPTCODE(HAS_TEMP_PROBE,   case H_PROBE:   SERIAL_ECHOPGM(STR_PROBE);          break)
      OPTCODE(HAS_TEMP_BOARD,   case H_BOARD:   SERIAL_ECHOPGM(STR_MOTHERBOARD);    break)
      OPTCODE(HAS_TEMP_CHAMBER, case H_CHAMBER: SERIAL_ECHOPGM(STR_HEATER_CHAMBER); break)
      OPTCODE(HAS_TEMP_BED,     case H_BED:     SERIAL_ECHOPGM(STR_HEATER_BED);     break)
      default:
        if (real_heater_id >= 0) SERIAL_ECHOLNPGM("E", real_heater_id);
    SERIAL_EOL();
  disable_all_heaters(); // always disable (even for bogus temp)
  hal.watchdog_refresh();
  #if BOGUS_TEMPERATURE_GRACE_PERIOD
    const millis_t ms = millis();
    static millis_t expire_ms;
    switch (killed) {
      case 0:
        expire_ms = ms + BOGUS_TEMPERATURE_GRACE_PERIOD;
        ++killed;
        break;
      case 1:
        if (ELAPSED(ms, expire_ms)) ++killed;
        break;
      case 2:
        loud_kill(lcd_msg, heater_id);
        ++killed;
        break;
  #elif defined(BOGUS_TEMPERATURE_GRACE_PERIOD)
    UNUSED(killed);
  #else
    if (!killed) { killed = 1; loud_kill(lcd_msg, heater_id); }
  #endif
OR
void Temperature::disable_all_heaters() {
  // Disable autotemp, unpause and reset everything
  TERN_(AUTOTEMP, planner.autotemp_enabled = false);
  TERN_(PROBING_HEATERS_OFF, pause_heaters(false));
  #if HAS_HOTEND
    HOTEND_LOOP() {
      setTargetHotend(0, e);
      temp_hotend[e].soft_pwm_amount = 0;
  #endif
  #if HAS_TEMP_HOTEND
    #define DISABLE_HEATER(N) WRITE_HEATER_##N(LOW);
    REPEAT(HOTENDS, DISABLE_HEATER);
  #endif
  #if HAS_HEATED_BED
    setTargetBed(0);
    temp_bed.soft_pwm_amount = 0;
    WRITE_HEATER_BED(LOW);
  #endif
  #if HAS_HEATED_CHAMBER
    setTargetChamber(0);
    temp_chamber.soft_pwm_amount = 0;
    WRITE_HEATER_CHAMBER(LOW);
  #endif
  #if HAS_COOLER
    setTargetCooler(0);
    temp_cooler.soft_pwm_amount = 0;
    WRITE_HEATER_COOLER(LOW);
  #endif
For the bed enable maybe and if statement here for enable if (celsius) BED_ENABLE_PIN = 1; or add it to the power manager?
static void setTargetBed(const celsius_t celsius) {
        TERN_(AUTO_POWER_CONTROL, if (celsius) powerManager.power_on());
        temp_bed.target = _MIN(celsius, BED_MAX_TARGET);
        start_watching_bed();
I think I am on the right path, I just want one of the code wizzards to verify. I'd also like to find out why pin control seems to not be working.
