Hi, I’m using SKR mini e3 v3 board and Marlin 2.1.x bugfix version. I want to increase the maximum temperature to 395. So I corrected lines 651 and 652 in the configuration.h file to 395, and the following error occurred, so I can’t build it.
====error====
PS C:\Users\user\Documents\Marlin-bugfix-2.1.x> platformio run --silent -e STM32G0B1RE_btt
Marlin\src\inc\Warnings.cpp:706:6: warning: #warning “Motherboard DIAG jumpers must be removed when SENSORLESS_HOMING is disabled. (Define DIAG_JUMPERS_REMOVED to suppress this warning.)” [-Wcpp]
706 | #warning “Motherboard DIAG jumpers must be removed when SENSORLESS_HOMING is disabled. (Define DIAG_JUMPERS_REMOVED to suppress this warning.)”
In file included from Marlin\src\module../inc/MarlinConfigPre.h:37,
from Marlin\src\module../inc/MarlinConfig.h:28,
from Marlin\src\module../MarlinCore.h:24,
from Marlin\src\module\temperature.cpp:30:
Marlin\src\module\temperature.cpp:302:14: error: static assertion failed: HEATER_0_MAXTEMP (395) is too high for thermistor_1.h with HOTEND_OVERSHOOT=15.
302 | S >= 998 || M <= _MA
TT_NAME(S)[0].celsius, TT_NAME(S)[COUNT(TT_NAME(S)) - 1].celsius) - (HOTEND_OVERSHOOT),
Marlin\src\module../inc/…/core/macros.h:643:24: note: in definition of macro ‘EVAL1’
643 | #define EVAL1(V…) V
Marlin\src\module../inc/…/core/macros.h:642:30: note: in expansion of macro ‘EVAL1’
642 | #define EVAL2(V…) EVAL1(EVAL1(V))
Marlin\src\module../inc/…/core/macros.h:641:24: note: in expansion of macro ‘EVAL2’
641 | #define EVAL4(V…) EVAL2(EVAL2(V))
Marlin\src\module../inc/…/core/macros.h:642:24: note: in expansion of macro ‘EVAL1’
Marlin\src\module../inc/…/core/macros.h:641:30: note: in expansion of macro ‘EVAL2’
Marlin\src\module../inc/…/core/macros.h:640:24: note: in expansion of macro ‘EVAL4’
640 | #define EVAL8(V…) EVAL4(EVAL4(V))
Marlin\src\module../inc/…/core/macros.h:640:30: note: in expansion of macro ‘EVAL4’
Marlin\src\module../inc/…/core/macros.h:639:24: note: in expansion of macro ‘EVAL8’
639 | #define EVAL16(V…) EVAL8(EVAL8(V))
Marlin\src\module../inc/…/core/macros.h:639:30: note: in expansion of macro ‘EVAL8’
Marlin\src\module../inc/…/core/macros.h:630:24: note: in expansion of macro ‘EVAL16’
630 | #define EVAL(V…) EVAL16(V)
Marlin\src\module../inc/…/core/macros.h:689:33: note: in expansion of macro ‘EVAL’
689 | #define REPEAT_S(S,N,OP) EVAL(REPEAT(S,SUB##S(N),OP))
Marlin\src\module../inc/…/core/macros.h:620:26: note: in expansion of macro 'CHECK_MAXTEMP’
620 | #define THIRD(a,b,c,…) c
Marlin\src\module../inc/…/core/macros.h:209:29: note: in expansion of macro ‘THIRD’
209 | #define ___TERN(P,V…) THIRD(P,V) // If first argument has a comma, A. Else B.
Marlin\src\module../inc/…/core/macros.h:208:29: note: in expansion of macro ‘___TERN’
208 | #define __TERN(T,V…) ___TERN(_CAT(_NO,T),V) // Prepend ‘_NO’ to get ‘_NOT_0’ or ‘_NOT_1’
Marlin\src\module../inc/…/core/macros.h:207:29: note: in expansion of macro ‘__TERN’
207 | #define _TERN(E,V…) _TERN(CAT(T,E),V) // Prepend 'T’ to get ‘T_0’ or ‘T_1’
Marlin\src\module../inc/…/core/macros.h:203:29: note: in expansion of macro ‘_TERN’
203 | #define TERN(O,A,
TERN(ENA_1(O),B,A) // OPTION ? ‘A’ : ‘B’
Marlin\src\module\temperature.cpp:304:28: note: in expansion of macro ‘TERN’
304 | #define CHECK_MAXTEMP(N) TERN(TEMP_SENSOR##N##IS_THERMISTOR, CHECK_MAXTEMP, CODE_0)(N, HEATER##N##MAXTEMP, TEMP_SENSOR##N)
Marlin\src\module../inc/…/core/macros.h:674:3: note: in expansion of macro ‘CHECK_MAXTEMP’
674 | _RPT_OP(_RPT_I)
Marlin\src\module../inc/…/core/macros.h:689:38: note: in expansion of macro ‘_REPEAT’
689 | #define REPEAT_S(S,N,OP) EVAL(_REPEAT(S,SUB##S(N),OP))
Marlin\src\module../inc/…/core/macros.h:690:33: note: in expansion of macro ‘REPEAT_S’
690 | #define REPEAT(N,OP) REPEAT_S(0,N,OP)
Marlin\src\module\temperature.cpp:305:3: note: in expansion of macro ‘REPEAT’
305 | REPEAT(HOTENDS, CHECK_MAXTEMP)
*** [.pio\build\STM32G0B1RE_btt\src\src\module\temperature.cpp.o] Error 1
========================================================================= [FAILED] Took 57.57 seconds =========================================================================
Environment Status Duration
STM32G0B1RE_btt FAILED 00:00:57.568
