Hello, dear plastic-melting community
I few months ago, I replaced the old electronics of my printer with a BIGTREETECH Manta M8P with Raspberry Pi 4.
Firmware: Marlin 2.1.2.1 / Marling 2.1.x (bugfix from 09. Aug 2024), config:
Configuration.zip
No Input shaping, S-curve, junction deviation or anything else fancy activated, just as basic as possible.
Host: Repetier Server
Hardware:
- X-Axis: Closed loop Servo Leadshine iSV2
- Y-Axis: Closed loop servo Clearpath-SD
- Z-Axis: Closed Loop Stepper JMC iHSS57-36-10-21-38
Everything worked fine so far, or so I thought. From time to time i discovered that the printed parts were a few 1/10mm smaller than the should have been. These were mostly simple large parts with few "islands", so only a few retracts. It wasn´t critical and minor enough that I thought it was just regular shrinking or warping due to the size.
Last time, I printed a build plate filled with multiple small, complex parts, many islands, many retracts, long print time (24h) for only 15mm of build height.
When I measured the parts, I´ve discovered that they were only 12,5mm tall, 2,5mm were missing.
Then I manually moved the Z-Axis down, the nozzle touched the printbed at a displayed Z-height of 2,5mm. So the Z-height apparently has been shifted by 2,5mm during the print.
After I discovered this, I checked the mechanics of the machine: Everything sits properly, there is nothing loose, all belts are tensioned, pulleys are fixed. There is no measurable backlash on the z-axis.
When I move the Z-axis manually, even 10 times several 100mm +-, the shift doesn´t appear.
It only seems to appear at a high number of Z - movements.
Then, I wrote a test gcode file which rapidly performs a small Z-movement followed by a small XY-movement which mimics a complex print with many small islands with Z-hops 7500 times in total with an additional Z+0,2 every 500 cycles. It´s attached:
Test.Z+-0.2.total.+3Z.+XY.rel.x7500.zip
It looks like this:
G91 ;set relative positioning
15x
(500x)
G1 Z0.2
G1 X0.2 Y0.2
G1 Z-0.2
G1 X-0.2 Y-0.2
followed by 1x
G1 Z0.2
G90 ;set absolute positioning
I´ve run this test G-Code with 3 different Marlin firmware versions:
Version 2.1.2.1: Z+0,25mm
Version 2.1.x (bugfix) from 11. Jun. 2024: Z-0,32mm
Version 2.1.x (bugfix) from 09. Aug. 2024 (latest version): Z-0,32mm
Z+ means the axis is higher than it is supposed to be (gap between nozzle and printbed at Z=0),
Z- means the axis is lower than it is supposed to be (nozzle crashes into printbed at Z=0).
The results are repeatable, always with identical values.
My Z-axis runs with 1280 steps/mm, 300mm/s² acceleration and 0 jerk. X-Axis is 160,22 steps/mm, Y-Axis 128,28 steps/mm, both 5000 mm/s² acceleration and 10mm/s jerk.
What I´ve tried so far:
- Decreased acceleration XY 4000 -> 1000, Z 300 -> 100, XY Jerk 10 -> 5: Same result (Z-0,28)
- Changed steps/mm on Z 1280 -> 1000 on Marlin only, motor settings weren´t changed: Same result (displayed Z-0,35mm, real: Z-0,28)
- Increased MINIMUM_STEPPER_PULSE_NS 3000 ->10000, MINIMUM_STEPPER_PRE_DIR_DELAY + POST_DIR_DELAY 5000 -> 10000: Same result (Z-0,28)
- Doubled step resolution on Motor and Marlin (Z Steps/mm 1280 -> 2560): Different Result (Z-0,14)
- Increased move distance for test program Z+-0,2mm -> +-0,4mm: Same result (Z-0,28)
- Added an "M400" - command (Wait for current moves to finish) before and after any Z movement: Different Result (Z+-0, no error). However, the M400 increases the execution time by 4, so that the test progranm, which usually takes ~18 min, now took 70 min to finish. It looks like M400 doesn´t only empty the move buffer, but also adds a delay before the next move is started.
- Decreased acceleration Z 300 -> 30: Same result (Z-0,28) (printtime of testfile almost doubled)
- Increased acceleration Z300 -> 1200: Same result (Z-0,28)
- disabled "classic Jerk", enabled "Junction deviation": Same result (Z-0,28)
- Enabled "S_Curve_Acceleration": Same result (Z-0,28)
So far I assume the following:
- The acceleration has no impact on the problem. Thus it seems like it´s no mechanical or power related issue since quadrupling the acceleration should definitely have an impact if this would be the case.
- The print time has no impact on the problem. I printed the test file with a much lower acceleration and with longer distances, without any change.
- There seems to be a constant amount of Z-shift / Z-move (or Z directional change), According to my math, its Z-0.0000186666mm / Z-move. This must be caused by a constant stream of additional steps on the Z-Axis, because doubling the steps/mm halves the Z-shift.
- The move buffer or path planner seem to be involved because the problem disappears when I interupt the Z-move with M400
- Changing the Marlin version does change the problem: Version 2.1.2.1: Z+0,25mm, Version 2.1.x (bugfix): Z-0,32mm, so it is quite clear that this issue is firmware related.
Any ideas what causes this problem?
So far I´m running out of ideas.
I still could revert to my old electronics (RADDS, Arduino Due and Repetier Server), but I want to use the modern features of Marlin in the future.
I think that it´s firmware related. Maybe it wasn´t discovered yet because the effect is only visible at large complex prints.
If someone has a similar hardware and firmware config, it would be great if you could run the test g-code to verify if this is a general Marlin problem or isolated to my system.
