Trying to add a GD32F303 board in Marlin September 28, 2024 07:39PM |
#define BOARD_KINGROON_KP3_V1_3_GD 5301 // Kingroon KP3s v1.3 (GD32F303RET6)
/** * Marlin 3D Printer Firmware * Copyright (c) 2024 MarlinFirmware [https://github.com/MarlinFirmware/Marlin] * * Based on Sprinter and grbl. * Copyright (c) 2011 Camiel Gubbels / Erik van der Zalm * * This program is free software: you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by * the Free Software Foundation, either version 3 of the License, or * (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program. If not, see [www.gnu.org]. * */ #pragma once /** * Kingroon KP3s 1.3 (GD32F303VET6) board pin assignments * Sold as "Kingroon KP3s Mainboard" * Preliminary support for the Professional Firmwware */ #include "env_validate.h" #if HOTENDS > 2 || E_STEPPERS > 2 #error "KINGROONKP3SV1.3 only supports two hotend / E-stepper." #endif // Validate stepper driver selections. //#if !AXIS_DRIVER_TYPE_TMC2208) || !AXIS_DRIVER_TYPE_Y(TMC2208) || !AXIS_DRIVER_TYPE_Z(TMC2208) || !AXIS_DRIVER_TYPE_E0(TMC2208) // #error "This board has onboard TMC2208 drivers for X, Y, Z, and E0." //#endif #ifndef BOARD_INFO_NAME #define BOARD_INFO_NAME "KINGROONKP3SV1.3" #endif #ifndef DEFAULT_MACHINE_NAME #define DEFAULT_MACHINE_NAME "Kingroon KP3s" #endif #define BOARD_WEBSITE_URL "kingroon.com" #define ALLOW_STM32DUINO #include "env_validate.h" #define BOARD_INFO_NAME "MKS Robin Nano V1" // // Release PB4 (Y_ENABLE_PIN) from JTAG NRST role // #define DISABLE_JTAG // // Thermocouples // //#define TEMP_0_CS_PIN PE5 // TC1 - CS1 //#define TEMP_0_CS_PIN PE6 // TC2 - CS2 //#define LED_PIN PB2 #include "../stm32f1/pins_MKS_ROBIN_NANO_common.h" #if HAS_TFT_LVGL_UI && FAN1_PIN != PB0 && HEATER_1_PIN != PB0 #define BOARD_INIT() OUT_WRITE(PB0, LOW) #endif
#elif MB(KINGROON_KP3_V1_3_GD) #include "gd32f3/pins_KINGROON_KP3S_V1_3_GD.h"
[env:GD32F303VET6_kingroon_kp3s] platform = [github.com] platform_packages = framework-arduinogd32 board = genericGD32F303VE board_build.core = gd32 monitor_speed = 115200 build_flags = ${common.build_flags} -std=gnu++14 -DHAL_STM32 -DPLATFORM_M997_SUPPORT -DUSBCON -DUSBD_USE_CDC -DTIM_IRQ_PRIO=13 -DADC_RESOLUTION=12 build_unflags = -std=gnu11 -std=gnu++11 build_src_filter = ${common.default_src_filter} + - + lib_ignore = SPI, FreeRTOS701, FreeRTOS821 lib_deps = ${common.lib_deps} SoftwareSerialM board_build.address = 0x08007000 board_build.ldscript = mks_robin_nano.ld board_build.rename = ROBIN_NANO.bin debug_tool = jlink upload_protocol = jlink extra_scripts = ${common.extra_scripts} pre:buildroot/share/PlatformIO/scripts/fix_framework_weakness.py pre:buildroot/share/PlatformIO/scripts/stm32_serialbuffer.py buildroot/share/PlatformIO/scripts/custom_board.py buildroot/share/PlatformIO/scripts/offset_and_rename.py
Error: Build environment 'GD32F303VET6_kingroon_kp3s' is incompatible with BOARD_KINGROON_KP3_V1_3_GD. Use one of these environments:
Re: Trying to add a GD32F303 board in Marlin September 28, 2024 08:20PM |
Admin Registered: 15 years ago Posts: 7,333 |
Re: Trying to add a GD32F303 board in Marlin September 29, 2024 06:58AM |
Error: This board doesn't support arduino framework!
[env:GD32F303VET6_kingroon_kp3s] extends = envTM32F103RE_maple build_flags = ${env
TM32F103RE_maple.build_flags} -DMCU_STM32F103VE -DTEMP_TIMER_CHAN=4 board_build.address = 0x08007000 board_build.ldscript = mks_robin_nano.ld board_build.rename = ROBIN_NANO.bin debug_tool = jlink upload_protocol = jlink
In file included from Marlin/src/HAL/STM32F1/tft/tft_fsmc.cpp:30:0: ~/.platformio/packages/framework-arduinoststm32-maple/STM32F1/system/libmaple/include/libmaple/fsmc.h:47:2: error: #error "FSMC is unavailable on your MCU" #error "FSMC is unavailable on your MCU"
Re: Trying to add a GD32F303 board in Marlin September 30, 2024 01:46AM |
Re: Trying to add a GD32F303 board in Marlin September 30, 2024 04:20PM |
. At the moment however most conversations around GD32 seem to be shutdown with a "Do not support"
