Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 27, 2024 03:27AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 27, 2024 03:27AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 27, 2024 05:11AM |
Admin Registered: 14 years ago Posts: 7,177 |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 27, 2024 04:11PM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 28, 2024 03:30AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 28, 2024 05:29AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 28, 2024 11:10AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 28, 2024 11:30AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 28, 2024 06:18PM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 28, 2024 08:33PM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 31, 2024 02:25AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 31, 2024 02:33AM |
Dust
check these are correct
#define X_MIN_POS 0
#define Y_MIN_POS 0
These are your home positions
Ie When you home X, the X endstop trigger point sets where X0 is for the hotend , if the hotend is actually left of the bed X_MIN_POS should be a negative number, so moving the positive of that value will nove to X0
When you home Y, the Y endstop position point sets where Y0 is for the hotend. if the hotend is two far forward then Y_MIN_POS should be a negative number, so moving the positive of that value will nove to Y0
You also need to set #define NOZZLE_TO_PROBE_OFFSET { 10, 10, 0 } correctly
Is you probe exactly 10mm to the right of the hotend and back 10mm from the hotend? The picture seems to show your probe in in front of the hotend,so that would be NOZZLE_TO_PROBE_OFFSET { 10, -10, 0 } but with correct measurements
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 December 31, 2024 09:07AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 03, 2025 05:23AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 03, 2025 04:26PM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 03, 2025 04:27PM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 03, 2025 05:45PM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 05, 2025 08:45AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 06, 2025 07:41AM |
Re: Bed Leveling marlin 2.1.2.x upgrade from marlin 1.0.0 to 2.1.2 January 15, 2025 04:35AM |
