can marlin share an SD card via WIFI on skr-2 board January 17, 2025 11:09PM |
/** * Native ESP32 board with WiFi or add-on ESP32 WiFi-101 module */ //#define WIFISUPPORT // Marlin embedded WiFi management. Not needed for simple WiFi serial port. //#define ESP3D_WIFISUPPORT // ESP3D Library WiFi management (https://github.com/luc-github/ESP3DLib)
#if ENABLED(WIFISUPPORT) // // WIFI // /** * ------- * GND | 9 | | 8 | 3.3V * (ESP-CS) PB12 | 10 | | 7 | PB15 (ESP-MOSI) * 3.3V | 11 | | 6 | PB14 (ESP-MISO) * (ESP-IO0) PB10 | 12 | | 5 | PB13 (ESP-CLK) * (ESP-IO4) PB11 | 13 | | 4 | -- * -- | 14 | | 3 | 3.3V (ESP-EN) * (ESP-RX) PD8 | 15 | | 2 | -- * (ESP-TX) PD9 | 16 | | 1 | PC14 (ESP-RST) * ------- * WIFI */ #define ESP_WIFI_MODULE_COM 3 // Must also set either SERIAL_PORT or SERIAL_PORT_2 to this #define ESP_WIFI_MODULE_BAUDRATE BAUDRATE // Must use same BAUDRATE as SERIAL_PORT & SERIAL_PORT_2 #define ESP_WIFI_MODULE_RESET_PIN PC14 #define ESP_WIFI_MODULE_GPIO0_PIN PB10 #define ESP_WIFI_MODULE_GPIO4_PIN PB11 #endif
Re: can marlin share an SD card via WIFI on skr-2 board January 18, 2025 01:37AM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: can marlin share an SD card via WIFI on skr-2 board January 18, 2025 03:09PM |
Re: can marlin share an SD card via WIFI on skr-2 board January 18, 2025 06:17PM |
Re: can marlin share an SD card via WIFI on skr-2 board January 18, 2025 11:12PM |
Re: can marlin share an SD card via WIFI on skr-2 board January 19, 2025 01:44AM |
Re: can marlin share an SD card via WIFI on skr-2 board January 19, 2025 04:08PM |
