[Marlin 2.1.2.1] BTT Octopus V1.1 - Issue with controlling fans
Posted by Cumpy Rules
February 06, 2025 10:20AM
Hi @all,
This is my first post in a forum since 8 years of 3D printing. I have been able to find a solution to all previous problems, but this time I have reached the limit of my knowledge... So, I have a problem (the most commonly used beginning of a conversation in a forum)...
I have BTT Octopus V1.1 STM32F446ZE_btt (512K).
This board has 6 FAN ports, and these drive me crazy...
I use no BTT Touch, but the 12864.
Here is the problem:
If I set the fan speed over the display:
Fan Speed for fan 1 -> All OK
Fan Speed for fan 2 -> fan 1 will be set
Fan Speed for fan 3 -> fan 1 will be set
Fan 4 not used
Fan Speed for fan 5 -> All OK
Fan Speed for fan 6 -> All OK
If I set with M106 Px Sxx:
The same happens with fans 1-3. Anytime fan 1 will be set, regardless of which fan was called. Fans 5 and 6 cannot be controlled by M106 – they do nothing.
The problem seems to be that the pins are protected, regarding M43:
PIN: PA8          M42 P8            FAN_PIN                                 protected
PIN: PE5          M42 P69          FAN1_PIN                               protected
PIN: PD12        M42 P60          FAN2_PIN                               protected
PIN: PD13        M42 P61          FAN3_PIN                               protected
PIN: PD14        M42 P62          FAN4_PIN                               protected
PIN: PD15        M42 P63          FAN5_PIN                               protected
In Configuration_adv.h no AutoFan is defined:
#define E0_AUTO_FAN_PIN -1
#define E1_AUTO_FAN_PIN -1
#define E2_AUTO_FAN_PIN -1
#define E3_AUTO_FAN_PIN -1
#define E4_AUTO_FAN_PIN -1
#define E5_AUTO_FAN_PIN -1
#define E6_AUTO_FAN_PIN -1
#define E7_AUTO_FAN_PIN -1
#define CHAMBER_AUTO_FAN_PIN -1
#define COOLER_AUTO_FAN_PIN -1
#define EXTRUDER_AUTO_FAN_TEMPERATURE 50
#define EXTRUDER_AUTO_FAN_SPEED 255   // 255 == full speed
#define CHAMBER_AUTO_FAN_TEMPERATURE 30
#define CHAMBER_AUTO_FAN_SPEED 255
#define COOLER_AUTO_FAN_TEMPERATURE 18
#define COOLER_AUTO_FAN_SPEED 255
// Fan configuration
#define FAN_COUNT 6
#define NUM_M106_FANS 6
What could be the problem ?
Attached the complete configuration.h and configuration_adv.h.
Thanks in advanced
// Cheers CR
Edited 1 time(s). Last edit at 02/06/2025 10:23AM by Cumpy Rules.
open | download - configuration.h (127.9 KB)
open | download - configuration_adv.h (177.5 KB)
open | download - pins_BTT_OCTOPUS_V1_1.h (1.2 KB)
open | download - pins_BTT_OCTOPUS_V1_common.h (18.8 KB)
Re: [Marlin 2.1.2.1] BTT Octopus V1.1 - Issue with controlling fans
February 06, 2025 07:41PM
protected simply means that Marlin controls it, so you can't use M42 on that pin.
