Configure H question
Posted by tag1260
February 23, 2025 07:38PM
Is the configure h file the same from one version to the next? Can you just keep the same one from version to version if you wanted or do you have to completely re-write it every version?
Thanks
Re: Configure H question
February 23, 2025 09:58PM
No you cannot use older Configs on newer code versions.
The version number changes because the Config file has changed and is no longer compatible.
February 24, 2025 08:08AM
Thanks
