Hello,
I have invested about 40 hours now to compile and run Marlin for an stock CR 10 with an SKR mini E3 V2 with TFT35...
I ran into a lot of problems, but I could install a firmware.
The problem is only every time I start a print.
The printer heats up to the desired values. Moves a bid and then unloads all filament.
To then load filament.
To then get stuck into pause which I can not end with the TFT35
I thought that it might be an issue with the filament sensor, but I changed it and problems persist.
I think that the firmware for the board is as good as it can be but that the TFT is the problem.
Can I drop the TFT and use a standard marlin display that does not interfere with printing?
I feel tired and angry about Marlin and this BTT board and TFT.
Why can things just be install and go.
