Marlin Simulator Help
Posted by rq3
rq3
August 09, 2025 11:38AM
I have successfully compiled an executable with the Marlin simulator, but:
1) It will only run one time. If I exit, and then run the executable again, it shuts down, UNLESS I delete the imgui.ini and eeprom.dat files auto-created during the first run.
2) I cannot compile an executable with the TFT_COLOR_UI display.
I am using the latest bugfix, and the unchanged config files from the latest examples/simulator directory.
Any and all thoughts welcome!
Re: Marlin Simulator Help
August 09, 2025 12:11PM
2) not psychic. Error messages? Operating system? architecture?
Are you using example simulator configs? [github.com]
Did you install all requirements listed in native.ini for your OS?
Edited 1 time(s). Last edit at 08/09/2025 12:12PM by Dust.
August 09, 2025 12:29PM
Ok I see a static assert breaking things... "static assertion failed: Unsupported Character LCD Height" Is this your error?
click on the error to open up .pio/libdeps/{your build env}/MarlinSimUI/src/MarlinSimulator/hardware/HD44780Device.h:
find
static_assert(LCD_WIDTH == 16 || LCD_WIDTH == 20, "Unsupported Character LCD Width");
static_assert(LCD_HEIGHT == 2 || LCD_HEIGHT == 4, "Unsupported Character LCD Height");
change it to
#ifdef REPRAP_DISCOUNT_SMART_CONTROLLER
#endif
Will have to get this fixed in the sim.. [github.com]
Edited 3 time(s). Last edit at 08/09/2025 01:08PM by Dust.
rq3
August 09, 2025 01:03PM
@Dust, that worked a charm, but issue #1 still applies. I can only run the sim once, unless I delete the auto-generated files it creates on the first run. I've tried the obvious, like inializing EEPROM, etc.
Edited 2 time(s). Last edit at 08/09/2025 01:12PM by Dust.
August 09, 2025 01:12PM
I Can't replicate that... what OS and architecture?
rq3
August 09, 2025 01:25PM
Windows 10, 64 bit. When I run the sim, it creates eeprom.dat, imgui.ini, and spi_flash.bin files in the pio/build/simulator_windows folder where the newly compiled MarlinSimulator.exe file resides.
I have to delete the imgui.ini file to run the sim a second time, or it just briefly opens a blank screen, and then closes.
August 09, 2025 01:37PM
could you attach a imgui.ini for examination?
And what is your screen resolution? (wondering if its a 4k display or something high res causing issues)
Edited 1 time(s). Last edit at 08/09/2025 01:44PM by Dust.
rq3
August 09, 2025 01:40PM
And, as always, many thanks for your help!
open | download - imgui.ini (2.8 KB)
August 09, 2025 01:51PM
Its identical to my imgui.ini under linux..
rq3
August 09, 2025 02:02PM
Dust
I guess I can live with deleting it before I start the sim, but seems flakey to me.
Thanks, Dust!
August 19, 2025 03:29AM
I just watched a video of the Marlin Simulator.
I wasn't aware of that program and just learned of it from this post.
Pretty cool.
Edited 1 time(s). Last edit at 08/19/2025 03:32AM by brianmh13.
August 19, 2025 09:13AM
I too just learned of this simulator, though Will try it in Windows 11 Pro version 10.0.26100 Build 26100.
Just need to read the full article several times to determine what I need to do for Marlin Simulator setup in Windows 11 to execute the program correctly.
