New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 04:23AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 08:55AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 09:17AM |
pkm
Great, thanks!
Just downloaded and installed it.
I had to rename the file to RepRapFirmware-1.13.bin for the web-interface to recognize it as a firmware.
Uh-oh. I installed DuetWifi firmware to 0.8.5. Now it doesn't work, need to remember how to use bossac....
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 09:29AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 10:31AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 12:27PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 03:06PM |
yoorek
Hi David,
There seems to be a problem with configuring fan in thermostatic mode. I had it configured with M106 P1 T45 H1:2
It was working OK with 1.13beta1 release. Now with the new 1.13 on Duet 0.8.5 the fan does not come on once the hot end reaches 45 degrees. I can get it to work only by running M106 P1 T45 H-1 and then M106 P1 T45 H1:2
After disabling thermostatic mode with H-1 I can control the speed of the fan with plain M106 P1 S255 or M106 P1 S0 commands.
Furthermore once thermostatic mode is enabled and the fan turns off below 45 degrees it will not turn back on when the temperature becomes more than 45 degrees.
Am I doing something wrong even though it was working OK in the previous release? I attach my config.g just in case.
BTW do I have to set the PWM frequency using F parameter. If yes then what value should I use? The documentation says it is frequency and your release notes state that it is percentage.
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 16, 2016 03:12PM |
dc42
yoorek
Hi David,
Hi yoorek,
I think I've made a mistake in some code changed to the thermostatic fan control. It's apparently working on my delta, but what I suspect is happening is that the fan is turning on at only 50% PWM, and that my hot end fan is OK with that but your fan isn't. I'll correct it and release 1.13a in the next couple of days. In the mean time I suggest you revert to 1.13beta.
The fan PWM frequency defaults to 500Hz, which I found gives a good range of control using the fans I have. Your fans may provide better PWM control using a higher or lower PWM frequency. The F parameter is in Hz.
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 17, 2016 02:27PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 17, 2016 05:00PM |
Kurzaa
Will the Wifi and 0.8.5 firmware eventually be merged into one update?
Thanks for all your hard work and grats on the development of the DuetWifi.
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 17, 2016 08:12PM |
dc42
....... on the Diet 0.8.5 .......
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 17, 2016 08:17PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 21, 2016 05:19PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 24, 2016 02:18AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 24, 2016 03:21AM |
JimboRR
Hi
Since 1.13a my PanelDue shows 0 or 1% on fan speed. Fan speed 0-99 gives 0% and 100% gives 1% on the LCD.
I updated the PanelDue FW but it made no difference, I've also downgrades to 1.12 - 1.13beta1 to test and they work fine.
Works
1.12 and less
1.13 beta 1
Doesn't work
1.13a
Running on Duet 0.8.5
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 24, 2016 08:56AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 24, 2016 11:22AM |
doodad69
David,
Does this version include the M106 and M42 queuing, or is that still TBD?
Thx,
Pete
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 24, 2016 11:23AM |
dc42
JimboRR
Hi
Works
1.12 and less
1.13 beta 1
Doesn't work
1.13a
Thanks for the detailed feedback. I will fix this in the next release. There will probably be a 1.13b for the Duet WiFi soon, so I'll consider doing a 1.13b for the Duet at the same time.
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 June 24, 2016 02:44PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 July 17, 2016 08:50PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 July 17, 2016 09:24PM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 July 18, 2016 04:54AM |
Re: New RepRapFirmware/DuetWiFiFirmware 1.13 August 07, 2016 12:37PM |
