I'm not sure if this should be in the CoreXY or Duet section tbh, but here we are...
This is getting embarassing.
Ok, so I've built myself a 300x300 D-Bot running 24v / Duet 0.8.5 / 0.9° / Titan / V6 / Hall stops / IR probe (DC42).
I've got most things working as they should in terms of temps, e-stops, extrusion length and motor travel distance etc.
As I've seen some conflicting info, this first timer needs a little help to clarify a few things if you'd be so kind.
- Where should 0,0 home be? I currently have it at the back left against the X stop (Y stop is at the back right).
- I'm using web control. Which direction should +X, +Y and +Z move the carriage and bed as you're looking at the printer from the front?
Currently, +X moves the carriage left, +Y moves the carriage back and +Z moves the bed down.
The coordinates for the centre of the bed are X-145, Y-145 (290x290 working area). Should these be positive numbers instead?
I can currently home X and Y with no problems.
Homing Z is proving to be a pain. If I follow
these instructions, I can't move X/Y anywhere after homing them using either gcode commands or the movement buttons to get them to the center of the bed, so I'm kind of stuck on this one.
If I then press home Z just to see what happens, X/Y start trying to force their way into the back rail.
Left motor is plugged into Y, right into X.
Here's my sys config:
Machine configuration
M569 P0 S0 ; Drive 0 goes forwards (change to S0 to reverse it)
M569 P1 S1 ; Drive 1 goes forwards
M569 P2 S1 ; Drive 2 goes forwards
M569 P3 S1 ; Drive 3 goes forwards
M569 P4 S0 ; Drive 4 goes forwards
; If you use an endstop switch for Z homing, change Z0 to Z1 in the following line, and see also M558 command later in this file
M574 Y1 Z0 S1 ; set endstop configuration (X and Y and endstops only, at low end, active high)
M574 X1 S0
M667 S1 ; set CoreXY mode
M92 X200 Y200 Z800 ; Set axis steps/mm
M92 E417:417 ; Set extruder steps/mm
M906 X800 Y800 Z800 E900 ; Set motor currents (mA)
M201 X800 Y800 Z150 E800 ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z500 E300 ; Maximum speeds (mm/min)
M566 X600 Y600 Z30 E20 ; Maximum jerk speeds mm/minute
M208 X290 Y290 Z237 ; set axis maxima (adjust to suit your machine)
M208 X0 Y0 Z0 S1 ; set axis minima (adjust to make X=0 and Y=0 the edges of the bed)
G21 ; Work in millimetres
G90 ; Send absolute coordinates...
M83 ; ...but relative extruder moves
; Z probe
M558 P1 X0 Y0 Z1 ; Analog Z probe, also used for homing the Z axis
G31 Z3.21 P537 ; Set the probe height and threshold (put your own values here)
; The following M557 commands are not needed if you are using a bed.g file to perform bed compensation
;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the Z probe
M557 P0 X-10 Y-10 ; Four...
M557 P1 X-280 Y-10 ; ...probe points...
M557 P2 X-280 Y-280 ; ...for bed...
M557 P3 X-10 Y-280 ; ...levelling
;M557 P4 X-145 Y-145 ; 5th probe point for levelling
; Thermistors and heaters
;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
; You can also use S and B parameters to define the parameters of the thermistors you are using
M143 S300 ; Max hotend temp
M305 P0 R4700 T100000 B3950 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 R4700 T100000 B4388 H-1.4 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
M570 S120 ; Increase to allow extra heating time if needed
; Tool definition
M563 P0 D0 H1 ; Define tool 0
G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
;*** If you have a dual-nozzle build, un-comment the following 3 lines
;M563 P1 D1 H2 ; Define tool 1
;G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
;*** If you are using axis compensation, put the figures in the following command
M556 S78 X0 Y0 Z0 ; Axis compensation here
T0 ; select first hot end
Ok, no spoiler tags on here...
I've tried to provide as much relevant info as I can. Please let me know if you need anything more.
Cheers
Edited 1 time(s). Last edit at 08/17/2016 06:50AM by Mr Spangles.
