Is there anything I can put into my start code before the heater section that would cause the PanelDue to change screens and obtain working communication on the new screen prior to the heaters? Would a G4 P200 or G4 P500 pause the machine code long enough for the PanelDue to regain communication to the Duet prior to the M190 or M109 commands?
It appears if the PanelDue is already on the Print screen, everything works just fine when I start a print from the DWC. However, since the SD card button is now on the control screen on the PanelDue, when I select a print it switches to the Print screen, but the screen is frozen until the temps are at working setpoints and it starts the homing process in my start g-code.
