S3D Fan control
Posted by joestefano
S3D Fan control
January 20, 2017 07:18PM
I have my part fan connected to my DueX5 Fan3. How do I tell S3D that M106 is P3? Right now the S3D G code has M106 S255 after the first layer which is what I want. If I insert P3 into the code it runs fine. Any thoughts?
Re: S3D Fan control
January 21, 2017 02:14AM
If you have only one X carriage and therefore only one print cooling fan, the simplest option is to connect it to Fan0 and put whatever you currently have connected to Fan0 on Fan3.
The alternative is to use fan mapping in the tool definition. Add parameter F3 to your M563 tool definition command. It's supported in firmware 1.16 and later.
Edited 2 time(s). Last edit at 01/21/2017 02:17AM by dc42.
