Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 05:59AM |
; Configuration file for Duet 0.6 (firmware version 1.16) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Sun Dec 25 2016 16:06:25 GMT+0100 (Mitteleuropäische Zeit) ; General preferences M111 S0 ; Debugging off M501 G21 ; Work in millimetres G90 ; Send absolute coordinates... M82 ; ...and extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M665 R94 L217 B90 H285 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them ; Endstops M574 X2 Y2 Z2 S1 ; Define active high microswitches M558 P4 X0 Y0 Z0 H5 F120 T18000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds G31 P500 X0 Y0 Z-0.25; Set Z probe trigger value, offset and trigger height ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S0 ; Drive 1 goes backwards M569 P2 S0 ; Drive 2 goes backwards M569 P3 S1 ; Drive 3 goes forwards M92 X100 Y100 Z100 E160 ; Set steps per mm M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2) M906 X1300 Y1300 Z1300 E1300 I40 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Heaters M143 S260 ; Set maximum heater temperature to 260C M305 P0 T100000 B3950 H-10 R1000 ; Set thermistor + ADC parameters for heater 0 M305 P1 T100000 B3950 R1000 ; Set thermistor + ADC parameters for heater 1 ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Network M550 PDelta ; Set machine name M540 PBE:EFE:AD:0E:E0 ; Set MAC address M552 P192.168.178.17 S1 ; Enable network and set IP address M553 P255.255.255.0 ; Set netmask M554 P192.168.178.1 ; Set gateway ; Fans M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off ; Custom settings are not configured M572 D0 S0.15
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 08:33AM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 08:35AM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 08:51AM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 08:57AM |
; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool on Sun Dec 25 2016 16:06:25 GMT+0100 (Mitteleuropäische Zeit) ; Use relative positioning G91 ; Move all towers to the high end stopping at the endstops (first pass) G1 X285 Y285 Z285 F1800 S1 ; Go down a few mm G1 X-5 Y-5 Z-5 F1800 S2 ; Move all towers up once more (second pass) G1 X10 Y10 Z10 F360 S1 ; Move down a few mm so that the nozzle can be centred G1 Z-5 F18000 ; Switch back to absolute positioning and go to the centre G90 G1 X0 Y0 F18000
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 09:34AM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 10:27AM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 12:28PM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 15, 2017 12:32PM |
After the emergency stop the homing also failed as the Y-tower was way triggered before the other ones
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 28, 2017 05:53AM |
Re: Strange issues after upgrading from FW 1.16 to 1.17c with Delta January 28, 2017 08:38AM |
Treito
If I increase the value to 290 the 3DTouch crashes into the bed instead of getting triggered.
