Corexy bed sensor concept. Possible? March 02, 2017 03:25AM |
Re: Corexy bed sensor concept. Possible? March 02, 2017 03:30AM |
Re: Corexy bed sensor concept. Possible? March 02, 2017 11:08AM |
Re: Corexy bed sensor concept. Possible? March 02, 2017 01:23PM |
o_lampe
I'd go for 3 lead screws then. 4 screws always influence each other.
Question is: will you get more accuracy during the print with 4 (3) individual motors? I'd try to figure out a separate z-lift drive for adjustment only ( servo ?) and use only one stepper for all leadscrews.
Re: Corexy bed sensor concept. Possible? March 02, 2017 03:24PM |
Re: Corexy bed sensor concept. Possible? March 02, 2017 07:18PM |
Re: Corexy bed sensor concept. Possible? March 03, 2017 09:07AM |
Re: Corexy bed sensor concept. Possible? March 03, 2017 01:17PM |
Re: Corexy bed sensor concept. Possible? March 03, 2017 01:26PM |
BuildAThing
I would suggest having adjustment limits. For instance you need to decide which corner is low or high and limit how far you will go to correct the level. You do not want to find your printer bed jammed at an angle because you had a positioning problem.
