Hello,
I have passed quite a few hours on trying to troubleshoot my dual Z homing on my duet:
Board: Duet 2 WiFi (2WiFi)
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.3 (2021-06-15)
Duet WiFi Server Version: 1.26
upon startup, if I manual enter in the console:
G91
G1 H2 Z30 F6000
G1 H2 Z-30 F6000
All good, as both motors are moving in the right direction and the bed is moving +/-3cm.
M122:
Driver 0: position 0, standstill, SG min/max not available
Driver 1: position 0, standstill, SG min/max not available
Driver 2: position 192210, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max not available
Driver 4: position 0, standstill, SG min/max not available
if I run after
G1 H
1 Z-30 F1800
only 1 motor moves... which is an issue for homing. I have no clue what is wrong.....
Could you please help?
I attached my config.g, homeall.g and homez.g.
I tried switch motor cables Z1<->Z2 and it just changed the problem to the other motor.
Edited 1 time(s). Last edit at 11/20/2021 06:25AM by happycaribou77fr.
