Duet development news
Posted by dc42
Re: Duet development news
April 23, 2016 01:12PM
I am using old Compaq server PSUs, they have a decent 32amps at 12V output, as well as 5A at 5V (I bought at £10 each including shipping). But you can also get 12V to 5V converters for a couple of quid from ebay, they will do 2A or more.
I appreciate it is always more convenient to have everything on board, but where do you draw the line? Someone will always want more - to run LED strings, RasPi, hub, keyboard, mouse, recharge their tablet/phone...
What is Open Source?
What is Open Source Hardware?
Open Source in a nutshell: the Four Freedoms
CC BY-NC is not an Open Source license
April 23, 2016 01:22PM
bobc
The line is on the other side of all the stuff I want. grinning smiley
From other electronics I have worked with that supplies a 5V line, they normally only put on something big enough for their needs. Seems that is not the case with the Duet. There is some extra available. If it would have been just a matter of changing out a few components to supply more current, thought it would be a nice addition. Since the Duet has a nice web interface, I don't need to run OctoPrint. However, to get wireless, I need to run something like the TP-Link. Being able to just get power for it from the board would be nice and it sounds like I should be able to do that as long as I don't run the Panel.
April 23, 2016 01:28PM
ElmoC
Hi ElmoC yes that should be fine
@BobC indeed!
DuetWifi.: advanced 3d printing electronics
April 23, 2016 05:41PM
PRZ
I get the point not having 12V on a 24V machine, but 5V IS available and widen the choice for the controlled fans.
At the very minimum, the controlled fan LED rail shall be disconnectable to be able to supply in 5V without tricky wiring.
That could probably be done, but would users be happy to have a choice between all the controlled fans driven from 5V and all driven from Vin? What about the always-on fans?
April 23, 2016 05:44PM
ElmoC
bobc
Even with a PanelDue, if the TPLink only takes 150mA that should be no problem. The PanelDue takes about 330mA with the 4.3" screen, 630mA with the 7" screen, and somewhere in between with the 5" screen.
April 23, 2016 05:50PM
dc42
PRZ
Yes, I suggested a selection jumper earlier. It's not hard to find most fans in most form factors in 5v, 24v not so much. An always on fan thats at "system voltage" can just be wired in to the power supply, although convenient to have a connector on board, it's really not strictly needed.
PRZ
April 23, 2016 07:08PM
Yes, all fans in 5V is easier than all in 24V.
My point was also to avoid installation of a diode to protect the 5V input from Vin going through the LED (that is what I have done).
I've thought to destroy the LED to cut the path, but that is a bit barbarian.
And I am not sure of the interest of controlled fan LEDS. Never had a look at them.
April 23, 2016 07:26PM
dc42
Checking the RPi/Camera and I see it staying in the low 500ma range with spikes up to 660ma. So given the draw on the 7" screen, powering the RPi/Camera should be okay. Not sure if both the TP-Link and Pi would be safe to power together. But I think running the TP-Link separate is probably a better idea so it can stay powered on when the printer is off.
April 23, 2016 09:34PM
That should be workable!
cheers
Tony
May 02, 2016 04:07AM
I guess that the design of DuetNG is fairly well advanced, and it might be a bit late for feature requests. It would be nice to make Duet a bit more "Arduino friendly", i.e. allow a seamless programming experience from the Arduino IDE. I have added files to CoreDuet so a Duet can be added to Arduino IDE via Boards Manager. To program a Duet, I need to do Erase+reset before download, then usually a Reset after download. Otherwise, a user can write sketches in the Arduino IDE and program the board like other Arduino compatible boards.
Adding a 16u2 and programming port as on the Due would add unnecessary cost to the DuetNG, so my suggestion is to add a 6 pin header which includes the Erase and Reset signals. Then an external adapter can provide Arduino compatible programming. The makers of the Taijuino use such a method for their version of Due : [www.elechouse.com]
Their programming board looks like this
I don't think their programming board is Open Source, but an OS version is easy to create.
The minimum would be to add Erase, Reset,TX/RX to a header somewhere on the board, I think all those signals are available externally on Duet 0.8.5 already except Erase.
May 09, 2016 07:08PM
Here is a progress update.
Testing of the first prototype board has gone very well. We could put it into production with the only design change being the addition of one capacitor. However, we always intended to make further improvements to the capability of the board. These have been finalised, and a second prototype is currently being manufactured.
Once I have received and tested this and confirmed that no changes to the design are required, we plan to do a small run of pre-production boards. Some will be used for in-house soak testing. A few will be given to our OEMs and a small number of beta testers. We are also considering making some available to early adopters at a special price, bearing in mind that they may not be exactly the same as the final.productin boards.
We are not yet revealing the final specifications of the board or the major new features. However, we have listened to your comments and as a result the new Duet will have the following:
* Three low current PWM outputs for fans or similar devices, instead of two
* Fan power jumper selectable between Vin and 5V
* And of course larger terminal blocks for the hot end heaters, which I announced already.
May 09, 2016 07:15PM
Just a minor thing, but will the mounting holes and size be the same as the existing Duet?
May 09, 2016 09:15PM
Sounds good dc42, sort of sad that I have a 0.8.5 coming to continue my build, the DuetNG will be an upgrade for that machine though.
With more people using external heater SSR's, it's a pity not to have a small 2 pin header for external SSR connection.
May 09, 2016 09:19PM
aussiephil
Maybe the board could be designed with holes for both the bigger connector and a Molex KK style one? That way if you want the smaller connector, you can unsolder the big one and add the smaller one. At least with the current screw connectors for the hot ends, I was able to remove those and replace them with Molex connectors. I would hope the new board also keeps the 0.1" spacing for those connectors.
May 10, 2016 01:41AM
ElmoC
aussiephil
I'm sure the board is well and truly locked down at prototype two and having done lighting controller designs I know I would have the layout locked in by now, I guess I'm just being wistful for something that the greater majority won't need smiling smiley.
May 10, 2016 02:56AM
aussiephil
The Duet 0.6 has an EXT_FET connector that you could use for driving an SSR as an alternative to using the bed heater output terminals. I didn't notice until now that the Duet 0.8.5 doesn't have that connector.
PRZ
May 10, 2016 07:58AM
May be too late,
but I already suggested to provide a supplementary thermistor input to control ambiant temperature (in or atop the printer) for fire safety.
Pierre
- Safety [reprap.org]
- Embedded help system for Duet and RepRap Firmware [forums.reprap.org]
- Enclosed delta printers Lily [rouzeau.net] and Lily Big [rouzeau.net]
- OpenScad delta printer simulator [github.com]
- 3D printing on my site [www.rouzeau.net]
May 10, 2016 08:14AM
PRZ
May be too late,
You could achieve that using a spare thermistor channel if you have one. If you don't, then you probably don't have an expansion board connected, in which case you can connect an extra thermistor to one of the expansion connector thermistor channels along with a 4.7K pullup resistor to 3.3V.
PRZ
May 10, 2016 08:45AM
Using expansion connector is workable, but not practical, that need to have flying components and 1 pin connections, and if I follow same schematic, there is also a capacitor to add. A safety feature shall be straightforward.
dc42
PRZ
May be too late,
Pierre
May 10, 2016 11:13AM
PRZ
The capacitor would not be needed because it will be integrated in the new Duet.
While it's nice to have safety features, I don't know of anyone else who has implemented a safety temperature sensor as you describe. Several people have configured a smoke alarm to shut off power to the printer if it goes off, which IMO is a better system, not least because it is completely independent from the main printer electronics, and therefore not affected by hardware failure or short circuits within the printer electronics and wiring.
May 10, 2016 11:32AM
PRZ
May be too late,
A safety system like this needs to be independent of the printer. If the printer catches fire, probably the first thing that will go is the controller.
May 10, 2016 12:45PM
dc42
David, which drivers you decided to use in the last prototype?
May 10, 2016 03:01PM
Dc42 do you have more details about these smoke detectors? The ordinary ones that will be mounted on the ceiling with a potential free contact or is there a design out there that will be mounted nearby the printer?
Slicer: Simplify3D 4.0; sometimes CraftWare 1.14 or Cura 2.7
Delta with Duet-WiFi, FW: 1.20.1RC2; mini-sensor board by dc42 for auto-leveling
Ormerod common modifications: Mini-sensor board by dc42, aluminum X-arm, 0.4 mm nozzle E3D like, 2nd fan, Z stepper nut M5 x 15, Herringbone gears, Z-axis bearing at top, spring loaded extruder with pneumatic fitting, Y belt axis tensioner
Ormerod 2: FW: 1.19-dc42 on Duet-WiFi. own build, modifications: GT2-belts, silicone heat-bed, different motors and so on. Printed parts: bed support, (PSU holder) and Y-feet.
Ormerod 1: FW: 1.15c-dc42 on 1k Duet-Board. Modifications: Aluminium bed-support, (nearly) all parts reprinted in PLA/ ABS, and so on.
May 10, 2016 05:47PM
uvarovkv
The first prototype used A4982 drivers, same as the existing Duet. We're not revealing what drivers are on the second prototype until we have done some stress testing and thermal testing, in case they don't meet our expectations and we have to revert to A4982 drivers or choose something else.
May 10, 2016 05:49PM
Treito
I can't remember the details. There was a thread about it in the Safety section of these forums, about a year ago AFAIR.
May 10, 2016 06:02PM
Treito
Maybe this one or MQ2 gas detector selling by 3DMS ...
May 10, 2016 06:05PM
dc42
uvarovkv
but it is so noisy sad smiley ...as other describe it on this forum
May 11, 2016 03:39AM
Shame on me! eye rolling smiley I have an Arduino sensor kit, but I have not taken a deeper look at it and guess what: There is a gas sensor included.
But I also hoped that there is a ready solution. I know there are ordinary smoke detectors for rooms which provide a potential free contact for registering alarms, but that would be oversized.
The gas sensor board would need some sort of additional controller platform (Arduino based?).
I also think that it shouldn't be connected to the Duet itself for safety reasons and I think that theme is done for here and should be discussed seperately if wanted.
May 11, 2016 06:01AM
dc42
Treito
I found the thread: [forums.reprap.org]
May 13, 2016 07:51AM
The positioning of a smoke detector is important. If they are mounted in the wrong orientation they can be pretty useless.
Dave
