Re: Duet development news May 16, 2016 03:17PM |
dc42
The Duet 0.8.5 already has the larger bed heater terminal block. It has 2.5mm pitch screw terminals for the hot ends. The hot end wires in T3P3's kits fit these well enough, but in response to user feedback we are moving to larger hot end terminal blocks for the NG.
and yes i really do need to use 1/8th or 1/4 microstepping with the Flex3Drive - using 1/16th and 1A (way higher than is recommended) the motor is still struggling.
Re: Duet development news May 23, 2016 07:20AM |
Re: Duet development news May 23, 2016 07:48AM |
Re: Duet development news May 23, 2016 08:00AM |
Gaou
would it be possible to add some more probe points for bed levelling ? for now you can add a fifth point as i know. but it would be nicer if we can add some more.
Re: Duet development news May 23, 2016 09:21AM |
Gaou
Re: Duet development news May 23, 2016 09:25AM |
Re: Duet development news May 23, 2016 10:59AM |
Re: Duet development news May 27, 2016 09:32AM |
Re: Duet development news May 27, 2016 12:07PM |
Koko76
Not sure if you've covered this elsewhere, but what kind of max step rate do you expect out of the new board?
Re: Duet development news May 27, 2016 12:18PM |
Super. I'm going to be using some 250x drivers, and although they will have selectable microstepping I'd like to push it as high as is reasonably possible.Quote
dc42
Koko76
We have yet to measure it, and it needs some new firmware written to make use of architectural improvements we have made to allow faster stepping. We are aware that some users want to use 64x or higher microstepping drivers without sacrficing travel speed, and we've taken steps to address that requirement.
Re: Duet development news May 30, 2016 09:32AM |
Re: Duet development news May 30, 2016 09:35AM |
Re: Duet development news May 30, 2016 12:12PM |
Re: Duet development news June 01, 2016 11:45AM |
Re: Duet development news June 01, 2016 12:35PM |
Re: Duet development news June 01, 2016 12:45PM |
Re: Duet development news June 01, 2016 12:59PM |
uvarovkv
David, sorry for irksome question winking smiley
But is there any news about the release date of DuetNG ?
ElmoC
Any chance of having a set of unpopulated 2.54mm holes in addition to the 3.5mm screw terminal for both the extruder and bed? Running a 40w heater at 24v is only 1.7a. Even at 12v it is only 3.3a. No need for huge wires. Personally, I hate having to deal with screw terminals and avoid them if possible. If we are using a SSR for the bed, no need for huge connectors.
Re: Duet development news June 01, 2016 02:03PM |
dc42
uvarovkv
If the prototypes work as well as we hope, then before the end of this month we expect to have pre-production boards (some of which will be offered for sale) and be accepting pre-orders for production boards. But we can't make any promises until we have finshed testing the new prototypes, which we should have within the next few days.
Re: Duet development news June 02, 2016 04:26PM |
Re: Duet development news June 08, 2016 08:05AM |
Re: Duet development news June 08, 2016 08:12AM |
Re: Duet development news June 08, 2016 08:30AM |
ElmoC
dc42
We've replaced the Ethernet socket by a WiFi adapter.
Sorry to hear that. This has just made the board unusable for myself, and probably others. Not everyone has their printer in a location with a good WiFi signal, or even have WiFi.
Re: Duet development news June 08, 2016 08:32AM |
ElmoC
dc42
Re: Duet development news June 08, 2016 08:34AM |
dc42
ElmoC
dc42
I'm sorry you feel that. Almost every home user has WiFi now, along with most businesses. Extending WiFi range is very simple, you just plug in a range extender. I did exactly that when I moved last February, because the router had to go temporarily in the garage where the phone socket is, and wouldn't reach my office with a good signal. A £20 range extender plugged into a socket in the kitchen solved the problem.
OTOH having an Ethernet port instead limits most people to using the printer in the room with the router, because home users don't normally have Ethernet cabling - why should they, when everything these days uses WiFi?
Re: Duet development news June 08, 2016 08:35AM |
uvarovkv
ElmoC
dc42
ElmoC, you are wrong! Today the some 802.11n wifi-stick for your PC or laptop sometimes cheaper than a long lan-cable.
I think many will appreciate the news that the board has wifi out of the box!
Well done, David!
Re: Duet development news June 08, 2016 08:43AM |
Re: Duet development news June 08, 2016 08:50AM |
ElmoC
Using your same argument, a person without the cable handy can use a WiFi adapter to connect. This is even documented in the Duet information. While a person with WiFi and no cable can use the new one and the old one, a person with only a cable can not us it. You said your switched to the screw terminals on the hotend to cater to more users. Seems like you took a step backward with this change and have restricted it to certain ones.
Re: Duet development news June 08, 2016 08:56AM |
ElmoC
dc42
Re: Duet development news June 08, 2016 10:58AM |
Sadly I personally agree, despite having an excellent wifi point inside the garage used for printing I would always hard wire things like this.
Re: Duet development news June 08, 2016 12:16PM |
