g code to make heater active February 19, 2016 10:16AM |
Re: g code to make heater active February 19, 2016 12:27PM |
Re: g code to make heater active February 19, 2016 03:52PM |
Re: g code to make heater active February 19, 2016 04:10PM |
Re: g code to make heater active February 19, 2016 04:22PM |
PRZ
However, M104 shall work as you write in DC42 fork, as indicated in the wiki ?
without T parameter M104 set temperature for the default tool.
Re: g code to make heater active February 25, 2016 01:49PM |
Re: g code to make heater active February 25, 2016 03:48PM |
RickRap
I have:
M563 P1 D0 H1
In config.g
It seems bed is tool 0 by default (no M563 command used)
Extruder is tool 1
Here are my settings:
Re: g code to make heater active February 26, 2016 01:02PM |
Re: g code to make heater active February 26, 2016 03:24PM |
Re: g code to make heater active February 26, 2016 09:05PM |
Re: g code to make heater active February 26, 2016 09:54PM |
;prepare the machine after a cold start for PLA printing M140 S65 ; Set the bed temperature and don't wait for it M104 S180 ; set the current hotend temperature to 180 and don't wait for it G28 ; home T0 G32 ; calibrate during heating phase M98 P/macros/brush.g ; call cleaning macro M109 S180 ; set the current hotend temperature to 180 and wait for it - M104 don't wait M190 S65 ; Set the bed temperature and wait for it G32 ; 2nd calibration taking into account heating and other stuff
Re: g code to make heater active February 27, 2016 03:28AM |
RickRap
Ok, I switched the heater to Tool 0
Now, if I enter the following in the command line:
T0
M104 T0 S221
Tool 0 gets selected and starts heating up
If I put those same commands into a macro, It will only go to Standby and not heat up.
I'm just looking for a way to have a macro start up the heater prior to printing.
Re: g code to make heater active March 08, 2016 12:07PM |
Re: g code to make heater active March 08, 2016 03:31PM |
Re: g code to make heater active March 10, 2016 12:35AM |
