Can't connect to Duet 0.6 March 08, 2016 07:57PM |
Re: Can't connect to Duet 0.6 March 09, 2016 12:29AM |
Re: Can't connect to Duet 0.6 March 09, 2016 02:12AM |
Re: Can't connect to Duet 0.6 March 09, 2016 08:52AM |
Gaou
first of all can you connect through usb and pronteface ? secondly did you changed the gateway too or only the ip of the printer? does ur utp cable work? when you plug it in the printer does the leds on the utp port switch on ?
you can edit the config file through the web interface.
Also you need to make sure that the IP address you chose for the printer is on the same subnet as your PC. So find out the IP address of your computer (e.g. if it is running Windows, run ipconfig from a command shell) and check that the IP address you assigned to the Duet differs only in the last of the four numbers, and is not already used by another device.
Re: Can't connect to Duet 0.6 March 09, 2016 10:06AM |
M550 PKossel ; Machine name (can be anything you like) M552 P0.0.0.0 ; IP address (0 = use DHCP) M554 P192.168.0.254 ; Gateway M553 P255.255.255.0 ; Netmask
Re: Can't connect to Duet 0.6 March 09, 2016 11:24AM |
Re: Can't connect to Duet 0.6 March 10, 2016 03:59AM |
PRZ
- Editing the config.g file and uploading it via FTP. This have the advantage that you always have an up to date copy of your configuration file in your computer.
To log in FTP, you shall use the machine name as defined in the config.g file, for the user name any name e.g. 'whatever' and the password as defined in the config.g file (the leading 'P' is not part of the name nor password)
You could be simultaneously be logged in FTP and in http (web interface). If you have difficulties to connect directly in FTP, connect first with the web interface, this helps FTP connection.
Re: Can't connect to Duet 0.6 March 10, 2016 08:24AM |
Re: Can't connect to Duet 0.6 March 10, 2016 09:45PM |
Re: Can't connect to Duet 0.6 March 11, 2016 03:56AM |
gmh39
Connected!
Edit - Now I am trying to tune the motor current by editing the Config.g file through the web interface, but everytime I go to "Apply Settings" I get an error saying:
"An AJAX error has been reported, so the current session has been terminated.
Please check if your printer is still on and try to connect again.
Error reason: Unknown message type or not authenticated"
Re: Can't connect to Duet 0.6 March 11, 2016 08:25AM |
Re: Can't connect to Duet 0.6 March 11, 2016 11:15AM |
gmh39
How do I do that? I thought the web interface was written into the firmware..
Re: Can't connect to Duet 0.6 March 11, 2016 06:57PM |
