New RepRapFirmware 1.09x-dc42 March 11, 2016 01:17PM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 07:46AM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 08:08AM |
critical_limit
David,
is there something changed in autocal routine in the 1.09x version?
After autocal my head is moving in waves over the bed. Same in chris version.
Back to 1.09k (my reference version) everything is working fine.
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 09:17AM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 11:12AM |
critical_limit
other thing is, that with 1.09k my Layerhight is shown correctly (0,2mm / 0,05mm) but with versions after 1.09k it is shown 1.2mm / 0,05mm every time.
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 11:23AM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 01:49PM |
dc42
critical_limit
Can you post your gcode file, or put it on Dropbox or somewhere else where I can get it?
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 01:55PM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 02:57PM |
critical_limit
dc42
critical_limit
No special gcode file. It is on every file. Using S3D as slicer.
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 03:03PM |
critical_limit
But with 1.09x the Layershift is back and it seems that nozzle is traveling not in a plane.
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 03:29PM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 03:45PM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 03:59PM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 04:05PM |
Re: New RepRapFirmware 1.09x-dc42 March 12, 2016 04:48PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 09:06AM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 09:14AM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 11:28AM |
dc42
I have now released 1.09x-dc42 (i.e. it is no longer a beta). This contains two bug fixes since beta3. One caused the Z probe and temperature readings to be inaccurate on Duet 0.8.5 boards, the other is to fix a network reliability issue.
If you are using 1.09x-beta3, please upgrade. You can do this on the Settings tab of the web interface by first uploading file iap.bin (if you haven't uploaded it before), then uploading RepRapFirmware-1.09x-dc42.bin. If the web interface doesn't prompt you to install the new firmware, send M997 to do that.
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 12:49PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 12:53PM |
dc42
Thanks for that. I see that you don't have a G32 or G30 command in there. What was the last thing you did before printing the file, when you have the problem - was it by any chance a G30?
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 02:10PM |
WZ9V
Which version of the web control should we use with this update?
PRZ
David, not found the Duet IAP on your Github, I assume this is what is issued by Chrishamm here ?:
[github.com]
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 04:28PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 03:30PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 06:46PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 06:49PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 07:33PM |
dc42
The mdns module creates the name from the printer name and the MAC address. I guess the MAC address is included to guarantee that if you have more than one printer on the network, they have unique names. You could rebuild the firmware to avoid appending the MAC address, in file mdns_responder.c.
Re: New RepRapFirmware 1.09x-dc42 March 15, 2016 03:15AM |
jmg123
Is there a way to set the name that appears in mdns? I'd like to be able to remove the MAC address from the name that appears via bonjour if possible.
Re: New RepRapFirmware 1.09x-dc42 March 15, 2016 02:07PM |
Re: New RepRapFirmware 1.09x-dc42 March 17, 2016 06:54AM |
Re: New RepRapFirmware 1.09x-dc42 March 21, 2016 05:33AM |
