Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 22, 2016 01:56PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 22, 2016 02:05PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 22, 2016 11:30PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 23, 2016 04:24AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 23, 2016 05:42AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 05:47AM |
Gaou
First of all chrishamm thanks a lot for ur work and especially the web control. I have installed it today the way you told ( uploading the zip file) and i am still running some connection problems. This time it is even worst as there are some cases that i cant connect through one of my w7 pc.
ElmoC
So, now that I upgraded, I was trying to access the Duet via Telnet and FTP. I was never able to get Telnet to connect. I was able to get on via FTP using the default password (reprap), but that was about it. I have set a different password in config.g, but that didn't change what FTP was wanting. Also, when I tried a 'dir' command, it responded that I had to use PASV first. I tried the 'passive' command, but that was reported as an invalid command. I am using the Windows 7 FTP command to try and access it. With telnet, neither the Windows or PUTTY could connect.
What am I doing wrong?
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 07:12AM |
chrishamm
Dario, I'm afraid there is no useful information in there - it looks like "Emergency STOP" was pressed on your web interface (or M997/M999 was sent), so I cannot spot an error in the firmware. If it rebooted due to an error, it would either show "watchdog" as the last reset reason or the reset code would look different.
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 07:45AM |
Ormerod187
After 48 hours without problems It happened by editing the config file and pressing "Apply setting"!
Is an old 0.6 board
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 09:11AM |
chrishamm
Ormerod187
Is an old 0.6 board
Hmm, if the printer is idle, the web interface will ask you to restart the controller once a new config file has been uploaded. If you click on "Yes", then the web interface will actually send M999 to the firmware, which will induce a firmware reset. I'll check the JS code once more, just in case...
I'm glad everything else is working well on your setup though.
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 09:34AM |
chrishamm
Hmm, Telnet should work anyway. I have no problems connecting to my machine with either PuTTY or Linux's default telnet utility. As for FTP, I suggest you install FileZilla and configure it as outlined here: [reprappro.com]
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 09:39AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 09:51AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 10:26AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 10:32AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 05:12PM |
showFanControl: false, // show fan controls
showFanControl: true, // show fan controls
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 06:10PM |
mhackney
@PRZ, I run 3 duets from a single instance of the browser (Firefox, Chrome and Safari all tested) with no problems. They do not share list items - if I add something to one, it stays unique to that one.It is true that when you flush the browser cache, you loose these list items. I've been leaning more on macros since they persist on the Duet CF card.
In addition to the list items, the appearance and behavior and UI timing items are also lost. The Show Fan Sliders is really the only thing I wish persisted. I've modified my local DWC to do exactly that.
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 08:04PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 24, 2016 08:47PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 05:12AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 08:24AM |
PRZ
Christian, you indicated in a post that the DWC configuration is stored in local storage.
It means you have to make a configuration for each browser/device you are using for printer control.
Also, you loose configuration if local storage is cancelled
I am using Firefox, where you could separately remove cookies and local storage.
I cancel cookies at the end of each session for privacy reasons, but local storage is supposedly NOT cancelled (I don't know if it is possible to check that). However, I lost DWC configuration at each new browser session.
So, I modified the file model.js to have my configuration permanent. This also have the advantage that the configuration does not depend from the point of access.
The problem is that this shall be redone at each DWC issue.
Might it be possible to store the configuration in a file on the SD card instead of the local storage, this file being independant from model.js, and not cancelled while updating ?
PRZ
Also, as you have now implemented M143 (I was quite interested by that, as I can run fairly hot and I experienced a few safety triggers) , you may define the temperature graph scale based upon the temperature defined by M143 ?
PRZ
And a last point, RepRapFirmware is beginning to be implemented on other boards than the Duet, so a more generic name for Duet Web Control may be pertinent ? And it may be workable to use this web interface on other firmware either.
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 09:44AM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 02:23PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 02:29PM |
David J
I've noticed a small problem with the latest DWC and DC42 firmware - I don't know which part is responsible - the indication of the number of layers performed so far is constantly showing 1200 in the total layers field (see attached screenshot).
The gcode was generated with Slic3r; I've run the code through a couple of different analysers and both report that the item should have 70 layers.
The gcode file is too large to attach directly; if you need to see it then I'll try to compress it.
Otherwise, everything is working as it should, and I like the firmware update facility!
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 02:36PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 02:38PM |
David J
Hmm - every other aspect of the file's info shows on the web pages... and *I think* verbose (or slic3r's equivalent) is turned on... I'll have to go and check.
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 25, 2016 02:44PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 27, 2016 09:16PM |
chrishamm
Your request is reasonable though, so I may add an option to store the settings on the Duet's SD card to a future DWC version.Quote
PRZ
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 27, 2016 10:24PM |
Re: New Duet Web Control 1.11 and RepRapFirmware 1.09z-ch March 28, 2016 03:46AM |
percar
is it possible to add the possibility of driving 2 stepper motors in sync for example to use 2 motors on Z axis
I have requirements to run 2 x axis and 2 z axis motors. I do not want to run them in series due to the amperage required
I currently have an azteg X3 pro but i want to replace it with my duet
I would appreciate any help
