Re: New RepRapFirmware 1.10-dc42 March 30, 2016 06:43AM |
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 07:19AM |
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 07:41AM |
pkm
BTW, what is the difference between your version and David's?
pkm
The firmware seems to work, thanks a lot!
Now IE11 loads DWC very fast on the troublesome PC too, and there's a delay in Chrome (on any PC). I can use Wireshark with Chrome, if you're willing to look at it.
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 08:32AM |
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 08:49AM |
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 09:10AM |
pkm
1.10+4-dc42 seems to work, thanks!
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 09:41AM |
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 10:02AM |
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 10:16AM |
critical_limit
@chris: is it possible to show the printspeed from a gcode file? You can readout first and other Layerheights, maybe it´s possible to catch the printspeed as well out of the infos in a gcode-file.
This would help a lot when testing same files sliced with differnt speeds.
Re: New RepRapFirmware 1.10-dc42 March 30, 2016 01:31PM |
Re: New RepRapFirmware 1.10-dc42 March 31, 2016 11:40AM |
Re: New RepRapFirmware 1.10-dc42 March 31, 2016 01:50PM |
That would be great! Last layer is on the graph anyway.Quote
chrishamm
Hmm, I guess I could replace "last layer time" on the print page with the current feedrate in my next version.
Simulating big files takes a while, but it will give you the most accurate print time estimation.
Re: New RepRapFirmware 1.10-dc42 March 31, 2016 04:45PM |
chrishamm
Re: New RepRapFirmware 1.10-dc42 April 02, 2016 08:37AM |
Re: New RepRapFirmware 1.10-dc42 April 02, 2016 08:58AM |
Re: New RepRapFirmware 1.10-dc42 April 02, 2016 04:42PM |
Re: New RepRapFirmware 1.10-dc42 April 03, 2016 04:17AM |
Re: New RepRapFirmware 1.10-dc42 April 03, 2016 09:39AM |
Re: New RepRapFirmware 1.10-dc42 April 03, 2016 04:24PM |
SleepyPrince
A while ago I heard that it was planned to have a function to run macro when the extruder endstop is triggered.
Has it been implemented yet? I am planning to add some sort of filament sensor to the Duet
Re: New RepRapFirmware 1.10-dc42 April 03, 2016 04:33PM |
Re: New RepRapFirmware 1.10-dc42 April 03, 2016 04:55PM |
PRZ
SleepyPrince
There is a new command M581 (and M582) which was documented on 22 march, where an endstop status change could trigger a macro, an emergency stop or a pause. [reprap.org]
I have not yet tested it, but I think that open a lot of possibilities. Yet the trigger is only on endstops (extruders or movement drives), but documentation suggests it may be extended later to other I/O pins.
Re: New RepRapFirmware 1.10-dc42 April 04, 2016 03:36AM |
dc42
I've given this some thought. It's possible to do, however, you need a UPS or SLA backup battery to do it propely. When a power failure occurs, you need enough power left to move the head away from the print, retract a little filament, and then run the hot end fan for long enough to prevent the filament melting and then solidifying in the top of the heat break.
Re: New RepRapFirmware 1.10-dc42 April 04, 2016 04:58AM |
pkm
dc42
I've given this some thought. It's possible to do, however, you need a UPS or SLA backup battery to do it properly. When a power failure occurs, you need enough power left to move the head away from the print, retract a little filament, and then run the hot end fan for long enough to prevent the filament melting and then solidifying in the top of the heat break.
If I just would like to stop the print and then continue it the next day, it's almost the same problem, right? How do I find where to restart?
Re: New RepRapFirmware 1.10-dc42 April 04, 2016 05:11AM |
dc42
Stopping the print and continuing the next day is easier. You would press the Pause button on the web interface or PanelDue, and we would provide an extra option to create a restore file on the SD card. We would need to save not only the head position when it was paused but also the file path, file position, current feed rate, fan speed, tool selected, temperatures, bed compensation or delta calibration values, pressure advance, firmware retraction settings and perhaps a few other things.
To resume, you would need to home the printer without the head colliding with the print (easy on a delta, not so easy on a Cartesian printer), then run the resume file.
This is likely to get implemented within the next few months, because some OEM customers for the Duet have asked for it.
Re: New RepRapFirmware 1.10-dc42 April 05, 2016 02:58PM |
Re: New RepRapFirmware 1.10-dc42 April 05, 2016 04:41PM |
Re: New RepRapFirmware 1.10-dc42 April 05, 2016 04:54PM |
Re: New RepRapFirmware 1.10-dc42 April 06, 2016 08:55AM |
Re: New RepRapFirmware 1.10-dc42 April 06, 2016 11:00AM |
M111 P1 S1 M122
Re: New RepRapFirmware 1.10-dc42 April 06, 2016 11:23AM |
chrishamm
Vergo, were you doing anything specific when it happened?
