Re: New RepRapFirmware 1.10-dc42 April 06, 2016 11:51AM |
M115
FIRMWARE_NAME: RepRapFirmware FIRMWARE_VERSION: 1.10+4 ELECTRONICS: Duet 0.85 DATE: 2016-03-30
ok
M111 P1 S1
Debugging enabled for modules: Network(1)
Debugging disabled for modules: Platform(0) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) PrintMonitor(8)
ok
Class Network spinning.
M122
LINK
xmit: 6287
recv: 9664
fw: 0
drop: 784
chkerr: 0
lenerr: 0
memerr: 784
rterr: 0
proterr: 0
opterr: 0
err: 0
cachehit: 0
ETHARP
xmit: 1
recv: 1034
fw: 0
drop: 144
chkerr: 0
lenerr: 0
memerr: 0
rterr: 0
proterr: 144
opterr: 0
err: 0
cachehit: 5905
IP_FRAG
xmit: 0
recv: 0
fw: 0
drop: 0
chkerr: 0
lenerr: 0
memerr: 0
rterr: 0
proterr: 0
opterr: 0
err: 0
cachehit: 0
IP
xmit: 6333
recv: 8486
fw: 0
drop: 0
chkerr: 0
lenerr: 0
memerr: 0
rterr: 0
proterr: 0
opterr: 0
err: 0
cachehit: 0
IGMP
xmit: 1
recv: 0
drop: 0
chkerr: 0
lenerr: 0
memerr: 0
proterr: 0
rx_v1: 0
rx_group: 0
rx_general: 0
rx_report: 0
tx_join: 1
tx_leave: 0
tx_report: 0
ICMP
xmit: 5
recv: 5
fw: 0
drop: 0
chkerr: 0
lenerr: 0
memerr: 0
rterr: 0
proterr: 0
opterr: 0
err: 0
cachehit: 0
UDP
xmit: 0
recv: 164
fw: 0
drop: 0
chkerr: 0
lenerr: 0
memerr: 0
rterr: 0
proterr: 0
opterr: 0
err: 0
cachehit: 0
TCP
xmit: 5172
recv: 8301
fw: 0
drop: 1217
chkerr: 0
lenerr: 0
memerr: 0
rterr: 0
proterr: 1217
opterr: 0
err: 0
cachehit: 0
MEM HEAP
avail: 1024
used: 196
max: 540
err: 0
MEM UDP_PCB
avail: 5
used: 4
max: 4
err: 0
MEM TCP_PCB
avail: 16
used: 1
max: 16
err: 0
MEM TCP_PCB_LISTEN
avail: 4
used: 3
max: 3
err: 0
MEM TCP_SEG
avail: 16
used: 0
max: 4
err: 0
MEM REASSDATA
avail: 2
used: 0
max: 0
err: 0
MEM FRAG_PBUF
avail: 8
used: 0
max: 0
err: 0
MEM IGMP_GROUP
avail: 8
used: 2
max: 2
err: 0
MEM SYS_TIMEOUT
avail: 8
used: 7
max: 7
err: 0
MEM PBUF_REF/ROM
avail: 4
used: 0
max: 2
err: 0
MEM PBUF_POOL
avail: 5
used: 5
max: 5
err: 784
Diagnostics
Used output buffers: 14 of 16 (16 max)
Platform Diagnostics:
Memory usage:
Program static ram used: 42104
Dynamic ram used: 39624
Recycled dynamic ram: 192
Current stack ram used: 2712
Maximum stack ram used: 4332
Never used ram: 12052
Last reset 00:25:30 ago, cause: power up
Last software reset code & available RAM: 0x0003, 10492
Spinning module during software reset: GCodes
Error status: 0
Re: New RepRapFirmware 1.10-dc42 April 06, 2016 02:42PM |
chrishamm
Vergo, were you doing anything specific when it happened?
ByteSlinger, am I right thinking you're using dc42's latest 1.10+4 firmware with my latest DWC 1.11? If you get a chance, please don't turn off your printer after the problem occurred, connect it via USB , send the following codes and post their output here:
M111 P1 S1 M122
Re: New RepRapFirmware 1.10-dc42 April 07, 2016 04:30AM |
Re: New RepRapFirmware 1.10-dc42 April 08, 2016 02:56PM |
Re: New RepRapFirmware 1.10-dc42 April 08, 2016 04:28PM |
Gaou
Guys something weird happen to me today while i was printing . After the pause command the nozzle lost it's position and particularly it get about 1.5 upper than it should be. Today that happened 3 times until the printing fails . This had happened once in the past on my second printer but i didn't payed attention as it was only one and i wasn't sure why this happened.
Re: New RepRapFirmware 1.10-dc42 April 09, 2016 02:12AM |
