M98 Not working April 04, 2016 08:59AM |
Re: M98 Not working April 04, 2016 09:22AM |
Re: M98 Not working April 04, 2016 09:24AM |
chrishamm
If you are using dc42's fork, you must specify the absolute file path in M98 like
M98 P/macros/LowerBed
unless it's present in /sys. My firmware fork first checks if the macro file is present in /sys and then in /macros, so you could omit the directory if you used it.
The file is in the /macros directory.
Re: M98 Not working April 04, 2016 09:44AM |
Re: M98 Not working April 04, 2016 10:00AM |
chrishamm
Maybe you're missing a space? Does "M98 P/macros/Lower Bed" work?
You can also enable logging for all successful G-codes on the settings page, which allows you to check what code the web interface sends to the firmware.
Re: M98 Not working April 04, 2016 06:41PM |
chrishamm
