Hotend wiring 0.6
Posted by s0me
Hotend wiring 0.6
April 04, 2016 05:40PM
It's a DUET 0.6 from replikeo.
Why would they put a 4 pin header instead of a screw terminal if it's meant for a hotend?
Has anyone wired the hotend to those pins?
Re: Hotend wiring 0.6
April 04, 2016 08:56PM
Whilst not that specific connector a similar Molex quick connect with 1mm Sq pins has
Current - Maximum per Contact 4.0A
40W heater @ 12v will be around 3.3A current so not an issue.
at 24v it's only 1.7A so even less of a concern
Cheers
April 05, 2016 02:43AM
s0me
probably for been capable of sending more amps. Anyway i have used two for positive and two for negative. If i can recall the two closest to the E0 temp are the positive ones and the other two are the negative.
Delta Printer
Duet 0.8.5 firmware 1.19
