Extra Fans, M106 and thermostatic mode
Posted by ElmoC
April 15, 2016 09:04PM
Can any of the available pins on the expansion header be configured to allow the M106 command to control it? I don't need PWM, but would like to control the fan on the hotend with thermostatic mode. The two PWM outputs are already being used by the part cooling fan and another fan on the case with the Duet. I am using the PWM on the case fan to run it at a lower speed to cut down on the noise. Since the thermostatic mode is either on or off, if I can control another pin that would be connected to a mosfet, to control the fan, that would be ideal.
Re: Extra Fans, M106 and thermostatic mode
April 16, 2016 02:05AM
Yes is could be done bit it would need a firmware change. I'll try to identify a suitable expansion pin that is unlikely to be in use for anything else.
April 16, 2016 06:28AM
dc42
That would be great. Thanks for all the hard work you have put into this.
