Creating wiki page "Duet wiring" April 28, 2016 03:56PM |
Re: Creating wiki page "Duet wiring" April 28, 2016 08:14PM |
Re: Creating wiki page "Duet wiring" April 28, 2016 10:09PM |
Re: Creating wiki page "Duet wiring" April 29, 2016 12:22AM |
Re: Creating wiki page "Duet wiring" April 29, 2016 02:41AM |
Re: Creating wiki page "Duet wiring" April 29, 2016 05:14AM |
Re: Creating wiki page "Duet wiring" April 29, 2016 09:04AM |
PRZ
In principle the Firmware know the E1 is used for chamber heating as it is defined by M141 (H0 is the bed, H1 is E0, H2 is E1, see M563) . However, there is a problem of timeout on Extruder heaters, as it is unique for all extruder heaters, so unsufficient for a chamber.
Re: Creating wiki page "Duet wiring" April 29, 2016 09:32AM |
Re: Creating wiki page "Duet wiring" April 29, 2016 12:19PM |
PRZ
Thanks David.
I got miscellaneous troubles with my chamber heating (most are my fault), but I definitely think enclosed printers are needed for miscellaneous reasons.
Though, the temperature control may not be that easy. Up to 100°C, positive heating is required, however at higher temp (110/130°C - real surface temp) and after may be half an hour, you may need to extract heat. There is a second fan control available on the Duet 0.8.5, so this is feasible.
