Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 06:27AM |
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 06:35AM |
dc42
jimustanguitar
I end up with a heater fault every couple of minutes using a thermocouple and a Max31855 board (Logxen from Uberclock/Smoothie). I've got a very nice, well insulated PTFE cabled thermocouple that I encapsulated in heatsink epoxy to shield the bare metal of the welded junction from the aluminum heater block like your wiki mentions...
Can you confirm that you are using firmware version 1.12a? How long are the cables between the Duet and the thermocouple board? Can you post a photo of the wiring?
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 07:51AM |
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 07:57AM |
David J
David,
I'm a bit late to this party, but I've just updated to 1.12a successfully on my Linux Mint 17.3 64-bit machine. Seems happy to connect to the web server without complaint, and will try to print something soon.
What's the current version for Chris's web server code?
Cheers,
David
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 08:08AM |
dc42
Thanks for the feedback. Can you still connect to the Duet using USB too?
The current version of DWC is 1.11.
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 11:33AM |
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 01:08PM |
dc42
stephenrc
Windows 10x64 and Chrome, both are up to date. Downloaded the whole firmware as a zip and the individual files as raw. I get an Install Error dialog with "The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering"
I found the problem. Git has changed all the line endings in duet.inf from CRLF to LF. I'll take a look at whether I can force git to treat duet.inf as a binary file. Meanwhile, attached to this post is the correct duet.inf with the original line endings.
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 01:09PM |
David J
USB update: I plugged the printer in, and all the right messages came up in dmesg and lsusb. Tried printing, didn't really seem to have a solid connection - then changed the USB lead to a known good one, and everything sprang into life... crummy old USB lead now in the bin.
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 01:35PM |
dc42
Thanks again for the feedback. FWIW the micro USB A/B connector on some Duet 0.6 boards don't give a reliable connection. I have to waggle the USB lead connected to one of my Duet 0.6 boards to make it work. The micro USB B connectors on Panel Due. Duet 0.8.5 and Duet NG are more reliable.
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 09:30PM |
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 09:54PM |
Re: New RepRapFirmware release 1.12-dc42 May 11, 2016 10:15PM |
Re: New RepRapFirmware release 1.12-dc42 May 12, 2016 10:15AM |
Re: New RepRapFirmware release 1.12-dc42 May 12, 2016 11:16PM |
dc42
Re: New RepRapFirmware release 1.12-dc42 May 13, 2016 04:57AM |
dc42
Re: New RepRapFirmware release 1.12-dc42 May 13, 2016 01:03PM |
Sorry about that, it was brief and poorly depicted.Quote
jimustanguitar
The thermocouple is a 1m cable
Re: New RepRapFirmware release 1.12-dc42 May 13, 2016 04:31PM |
Re: New RepRapFirmware release 1.12-dc42 May 14, 2016 06:48PM |
Re: New RepRapFirmware release 1.12-dc42 May 19, 2016 12:15PM |
Re: New RepRapFirmware release 1.12-dc42 May 19, 2016 12:35PM |
Re: New RepRapFirmware release 1.12-dc42 May 19, 2016 04:34PM |
Re: New RepRapFirmware release 1.12-dc42 May 20, 2016 06:32AM |
Re: New RepRapFirmware release 1.12-dc42 May 20, 2016 08:29AM |
jondel
The upload speed has been dramatic,going from 18.2 KiB/s to well over 287.2 KiB/s.
So many thanks to Christian and dc42 for all the effort invoved.
Re: New RepRapFirmware release 1.12-dc42 May 21, 2016 07:37AM |
Re: New RepRapFirmware release 1.12-dc42 May 21, 2016 12:48PM |
Re: New RepRapFirmware release 1.12-dc42 May 22, 2016 05:35AM |
aussiephil
I'm comfortably seeing 640Kb uploads with the defualt supplied 4Gb MicroSD card. suspect this will jump a lot with a faster card
Firmware Name: RepRapFirmware for Duet
Firmware Version: 1.12a (2016-05-10)
Web Interface Version: HTML: 1.11, JS: 1.11
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 03:44AM |
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 03:48AM |
Treito
Using Firmware 1.12-dc42 I often get "Ajax Communication errors". Is this a known problem? I tried Firefox with Windows 10 as well as Google Chrome with Android.
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 03:55AM |
RECEIVED: Diagnostics RECEIVED: Used output buffers: 1 of 32 (18 max) RECEIVED: Platform Diagnostics: RECEIVED: Memory usage: RECEIVED: Program static ram used: 45208 RECEIVED: Dynamic ram used: 40256 RECEIVED: Recycled dynamic ram: 552 RECEIVED: Current stack ram used: 2712 RECEIVED: Maximum stack ram used: 5436 RECEIVED: Never used ram: 6852 RECEIVED: Last reset 11:58:22 ago, cause: software RECEIVED: Last software reset code & available RAM: 0x0003, 6628 RECEIVED: Spinning module during software reset: GCodes RECEIVED: Error status: 0 RECEIVED: Bed probe heights: -0.016 0.250 1.379 0.984 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 RECEIVED: Free file entries: 9 RECEIVED: Longest block write time: 0.0ms RECEIVED: Slowest main loop (seconds): 0.054688; fastest: 0.000000 RECEIVED: Move Diagnostics: RECEIVED: MaxReps: 4, StepErrors: 0 RECEIVED: Heat Diagnostics: RECEIVED: Heater 0: I-accumulator = 0.0 RECEIVED: Heater 1: I-accumulator = 94.6 RECEIVED: GCodes Diagnostics: RECEIVED: Move available? yes RECEIVED: Stack pointer: 0 of 5 RECEIVED: macro is idle RECEIVED: http is idle RECEIVED: telnet is idle RECEIVED: serial is doing "M122" RECEIVED: aux is idle RECEIVED: file is doing "G1 X40.562 Y73.445 E0.0163" RECEIVED: Network Diagnostics: RECEIVED: Free connections: 16 of 16 RECEIVED: Free transactions: 24 of 24 RECEIVED: Webserver Diagnostics: RECEIVED: HTTP sessions: 0 of 8 RECEIVED: FTP connections: 0, state 0 RECEIVED: Telnet connections: 0, state 0
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 07:38AM |
RECEIVED: ok SENT: M122 RECEIVED: Diagnostics RECEIVED: Used output buffers: 1 of 32 (20 max) RECEIVED: Platform Diagnostics: RECEIVED: Memory usage: RECEIVED: Program static ram used: 45208 RECEIVED: Dynamic ram used: 40232 RECEIVED: Recycled dynamic ram: 576 RECEIVED: Current stack ram used: 2712 RECEIVED: Maximum stack ram used: 5444 RECEIVED: Never used ram: 6844 RECEIVED: Last reset 01:28:25 ago, cause: software RECEIVED: Error status: 0 RECEIVED: Bed probe heights: 0.002 0.108 1.227 0.996 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 0.000 RECEIVED: Free file entries: 10 RECEIVED: Longest block write time: 42.3ms RECEIVED: Slowest main loop (seconds): 0.220093; fastest: 0.000000 RECEIVED: Move Diagnostics: RECEIVED: MaxReps: 4, StepErrors: 0 RECEIVED: Heat Diagnostics: RECEIVED: Heater 0: I-accumulator = 0.0 RECEIVED: Heater 1: I-accumulator = 98.0 RECEIVED: GCodes Diagnostics: RECEIVED: Move available? no RECEIVED: Stack pointer: 0 of 5 RECEIVED: macro is idle RECEIVED: http is idle RECEIVED: telnet is idle RECEIVED: serial is doing "M122" RECEIVED: aux is idle RECEIVED: file is idle RECEIVED: Network Diagnostics: RECEIVED: Free connections: 15 of 16 RECEIVED: Free transactions: 24 of 24 RECEIVED: Webserver Diagnostics: RECEIVED: HTTP sessions: 0 of 8 RECEIVED: FTP connections: 1, state 2 RECEIVED: Telnet connections: 0, state 0 RECEIVED: ok SENT: M105 RECEIVED: ok T:209.9 B:63.8
