Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 09:17AM |
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 09:46AM |
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 11:01AM |
Re: New RepRapFirmware release 1.12-dc42 May 23, 2016 12:38PM |
Re: New RepRapFirmware release 1.12-dc42 May 24, 2016 06:07AM |
Re: New RepRapFirmware release 1.12-dc42 May 24, 2016 01:47PM |
Re: New RepRapFirmware release 1.12-dc42 May 24, 2016 03:00PM |
dc42
The only known cause of watchdog resets is, and has been for many versions, a hardware lockup. Two suggestions:
1. Check that the screws on the power input terminal block to the Duet are tight, also the ones on the PSU if it uses screw terminals.
2. If you have a USB cable connected to the Duet while printing, try printing from SD card with the USB cable disconnected.
Re: New RepRapFirmware release 1.12-dc42 May 25, 2016 06:52AM |
Re: New RepRapFirmware release 1.12-dc42 May 25, 2016 07:03AM |
Re: New RepRapFirmware release 1.12-dc42 May 25, 2016 07:30AM |
auser
Nice part, I see you used it before
[www.dropbox.com]
Is it done in PLA, does it not lead to problems with the heat?
Re: New RepRapFirmware release 1.12-dc42 May 26, 2016 05:12PM |
Ormerod187
Good morning,
I'm having random duet reset with:
Firmware Version: 1.12 (2016-05-07)
Web Interface Version: HTML: 1.11, JS: 1.11
It is rare but annoying
What to check?
Re: New RepRapFirmware release 1.12-dc42 May 26, 2016 05:57PM |
Re: New RepRapFirmware release 1.12-dc42 May 27, 2016 02:27AM |
Re: New RepRapFirmware release 1.12-dc42 May 27, 2016 02:09PM |
Re: New RepRapFirmware release 1.12-dc42 June 01, 2016 03:35AM |
dc42
Hi Dario, please upgrade to 1.12a, which is the current released version, in case it fixes the problem.
