Max distance from PanelDue to Duet 0.8.5 May 09, 2016 02:17AM |
Re: Max distance from PanelDue to Duet 0.8.5 May 09, 2016 02:38AM |
Re: Max distance from PanelDue to Duet 0.8.5 May 09, 2016 04:18AM |
Re: Max distance from PanelDue to Duet 0.8.5 May 09, 2016 04:59AM |
aussiephil
Ah Thanks David,
That has simplified cabling runs
point 1 no worries, we run SPI data for christmas lights well over 6M on Cat5 and 20AWG at much higher rates so should have no trouble finding some cable.
Already up sizing wiring to deal with voltage drops for the longer runs for everything.
Point 2 - surprised your only at 57600 actually
Actually that leads to another question if you check back in...... the mini height sensor will have close on 4M of cable to get back to the board, is it sensitive to noise or again should i just watch the total loop resistance of the cable run?
Cheers
Re: Max distance from PanelDue to Duet 0.8.5 May 09, 2016 09:27AM |
