Another little problem - using macros from gcode [SOLVED] May 13, 2016 11:41AM |
Re: Another little problem - using macros from gcode May 13, 2016 12:28PM |
Re: Another little problem - using macros from gcode May 13, 2016 12:33PM |
Re: Another little problem - using macros from gcode May 14, 2016 05:41AM |
Re: Another little problem - using macros from gcode May 14, 2016 01:03PM |
Re: Another little problem - using macros from gcode May 14, 2016 01:29PM |
dc42
David,
1. Are you certain that you called the macro file exactly "Z_240", with no ".g" or ".gcode" extension?
2. Does the macro file show up in the list of user macros in DuetWebControl or in PanelDue if you have one? If so, does it work?
DWC and PanelDue both use commands of the form "M98 P/macros/filename" to execute user macros.
Re: Another little problem - using macros from gcode May 14, 2016 06:49PM |
