New BETA firmware 1.13 with M581/M582 support May 27, 2016 04:14PM |
Added support for M581 and M582 commands
M25 pause command can now be used inside a macro file to pause a file being printed from SD card
Firmware update messages are now sent to USB and PanelDue (but the existing PanelDue firmware doesn't display them)
Added gcode queue underrun counter, displayed in M122 Move diagnostic info
M122 responses are now sent only to the comms channel that sent the M122 command
Added support for multiple firmware modules to be updated (for Duet NG)
Corrected a possible problem with multiple incompatible gcodes being executed concurrently
Support H parameter on M0 and M1 commands, for compatibility with chrishamm's fork
When executing M0/M1 commands and no print is paused, execute stop.g/sleep.g if they exist, for compatibility with chrishamm's fork
Treat M25 within the file being printed the same as M226
Added additional simulation modes to help identify bottlenecks
Don't disable all interrupts when starting a new move, to reduce interrupt latencyand avoid dropping characters received from PanelDue
Moved some utility maths functions to CoreNG
Re: New BETA firmware 1.13 with M581/M582 support May 27, 2016 07:12PM |
M581 T2 E1 S0 ; Enable 'Out of filament sensor' trigger for first extruder M581 T3 E2 S0 ; Enable 'Out of filament sensor' trigger for second extruder.
Re: New BETA firmware 1.13 with M581/M582 support May 28, 2016 02:56AM |
Re: New BETA firmware 1.13 with M581/M582 support May 28, 2016 09:07AM |
