extruder fan control based on temp simple question or feature May 29, 2016 08:17PM |
Re: extruder fan control based on temp simple question or feature May 29, 2016 11:19PM |
Re: extruder fan control based on temp simple question or feature May 30, 2016 04:06AM |
aussiephil
@DC42
hi David
I am so used with the Sailfish firmware on the Flashforge controlling the extruder cooling fans automatically I get frustrated that I have to manually turn off the extruder fan once the extruder temp drops low enough not to worry about jamming the hot end. (or forget to turn it on when changing filament)
Is there a way to do this in RRF?
if not is there any way this can be added with options to set turn on/off temp and fan % used?
Cheers and thanks for all your hard work
Phil
Re: extruder fan control based on temp simple question or feature May 30, 2016 05:41AM |
Re: extruder fan control based on temp simple question or feature May 30, 2016 07:48AM |
Re: extruder fan control based on temp simple question or feature May 30, 2016 08:50AM |
dc42
Currently the fan is either full on or full off when in thermostatic mode. It's on my list to make the on-speed controlled by the S parameter.
