New PanelDue firmware 1.14
June 12, 2016 04:29AM
I have released new PanelDue firmware at [github.com]. The changes in this release are:
- Implemented alert messages (M117)
- Added new state for firmware update
- Added ':' key to keyboard
- Close buttons are now always placed in the top right hand corner of the window
- Layer height is now displayed to 2 decimal places
- Icons are inverted correctly when the Invert Display option is used
I have also released a new version of iap.bin at [github.com]. This version sends firmware update progress messages to PanelDue.
Edited 1 time(s). Last edit at 06/12/2016 04:59AM by dc42.
Re: New PanelDue firmware 1.14
June 12, 2016 08:23AM
What is the difference between iap.bin and iap4e.bin?
Reality is in fact virtual.
June 12, 2016 01:04PM
Iap4e.bin is the version for the Duet WiFi.
June 12, 2016 03:50PM
Thanks. How does one dismiss the message after it is displayed with M117? I press the x (close) button but the message reappears again. I invoked it from DWC g-code console.
June 12, 2016 04:50PM
Thank you - I am looking forward to the update!
Unfortunately I just tried to update following the procedure and it displayed a "touch the sp..." where I couldn't see the spot and so it hung. I use the 4.3" Think3DPrint3D screen.
I imagine I have to adjust the expected screen size somewhere - could you please point as to how to do this to get it working with this screen?
Thank you
Edited 2 time(s). Last edit at 06/12/2016 04:53PM by Risingphoenix.
June 12, 2016 05:26PM
Risingphoenix
Thank you
Did you load the correct version of firmware? There are various versions for each supported screen size.
June 12, 2016 05:37PM
Sorry but thank you very much for taking the time to answer - you're absolutely correct... I overlooked the different screensizes and simply scrolled all the way down...
June 12, 2016 05:43PM
yoorek
You will need to upgrade the Duet firmware to 1.13 to fix that.
June 13, 2016 06:10PM
dc42
yoorek
Thanks, I'll just wait until 1.13 is released. Currently I'm on 1.13beta1
June 14, 2016 07:00AM
yoorek
dc42
yoorek
Oops, I thought the fix to M117 was already in 1.13beta1. I've put a preview of 1.13 release at [dl.dropboxusercontent.com]. I need to do so me more tests on the new features before I release it.
Edited 1 time(s). Last edit at 06/14/2016 07:00AM by dc42.
July 05, 2016 02:48PM
V1.14 works well with the 7" display I got from here
[www.ebay.co.uk]
Don't forget to do the 5V wire link mod if you have the version 1.0 PCB, and move the link to 5V position.
Documented by DC42 here
I'm very pleased, thanks David.
Regards,
Julian S.
T3DP3D Mini Kossel, E3D V6 hot end, 0.4mm nozzle, 200mm diameter Ali heated bed, Duet v0.8.5 & dc42 rep rap v1.18. DWC v1.15, PanelDue-7-1.16 DC42 IR Z Probe, 2 X MAX31855 &Thermocouples, PID heated enclosure, SolidWorks 2017, slic3r
July 05, 2016 03:20PM
JuJuDelta
[miscsolutions.wordpress.com].
Yes you need the link, however you must put the jumper in the 3.3V position, because the main supply (not the backlight supply) is 3.3V for the 7" display, just as it is for all the other non-Itead displays.
Edited 1 time(s). Last edit at 07/05/2016 03:21PM by dc42.
July 05, 2016 03:54PM
With the link in the 3.3v position, I got a noisy display with horizontal line jitter.
With the link in the 5v position, the display is crisp.
I'll put a scope on the supply and see if it's noisy, and maybe fit a cap here and there.
10uf tantrum + 100nf ceramic 0603
Edited 2 time(s). Last edit at 07/05/2016 03:59PM by JuJuDelta.
Regards,
Julian S.
July 05, 2016 05:58PM
You might like to check the legend on the display PCB by the 40-pin connector. The bottom left pin is marked Gnd and the one above that is usually marked 3.3V. That's the one that the voltage selection jumper feeds. I guess there may be a 7" display variant that takes 5V on that pin, but if so then I would expect the pin to be marked 5V instead of 3.3V.
You could also measure the voltage on the jumper to check that the regulator really is supplying 3.3V.
HTH David
Edited 1 time(s). Last edit at 07/05/2016 05:58PM by dc42.
July 05, 2016 06:01PM
PS also check that you fitted the link wire to the underside of the 5V pin on the voltage selection jumper, not the centre pin or the 3.3V pin.
July 06, 2016 04:24AM
Does anyone know if the Duet 0.6 (as supplied with the Fisher) can supply the 650ma power needed to drive the 7" display?
DC42 Kossel 330mm x 2meters
My Thingiverse Creations
July 06, 2016 11:28AM
Yes it can, assuming you have the onboard 5V switching regulator enabled.
