Re: Duet WiFi details published, pre-order window open June 24, 2016 08:14AM |
Fpex
I ordered one before the brevet at a much higher pound value, but no regrets. For as much anger I have for UK and its unilateral decision to bring us all back to a 2008 crisis (or worse), I do not mind have given you my support.
Re: Duet WiFi details published, pre-order window open June 25, 2016 05:29AM |
Re: Duet WiFi details published, pre-order window open June 25, 2016 05:35AM |
Re: Duet WiFi details published, pre-order window open June 25, 2016 06:53AM |
Re: Duet WiFi details published, pre-order window open June 25, 2016 06:56AM |
Fpex
I might have missed, will this board work also on 24v?
Fpex
But I guess it will not be able to drive a large 24v plate, right?
Re: Duet WiFi details published, pre-order window open June 25, 2016 09:40AM |
dc42
...That would be 360W @ 24V. For comparison, my delta printer with a 330mm diameter bed uses a 350W heater.
Re: Duet WiFi details published, pre-order window open June 25, 2016 10:31AM |
Re: Duet WiFi details published, pre-order window open June 26, 2016 11:28AM |
Re: Duet WiFi details published, pre-order window open June 29, 2016 07:02AM |
Re: Duet WiFi details published, pre-order window open June 29, 2016 08:21AM |
Re: Duet WiFi details published, pre-order window open June 30, 2016 04:04PM |
Re: Duet WiFi details published, pre-order window open June 30, 2016 04:20PM |
Calvinx66
Thanks for the reply.
Alas It wouldn't economic make sense to buy the non wifi board from the link advertised as it is the exact same price for an older generation board as the new one. You would have thought with the new board being released that the previous version would have been discounted somewhat.
So again I ask anyone got any ideas on an EU alternative ?
have seen Milkshake Board anyone used One ?
Regards
Re: Duet WiFi details published, pre-order window open June 30, 2016 04:23PM |
Re: Duet WiFi details published, pre-order window open June 30, 2016 06:08PM |
Re: Duet WiFi details published, pre-order window open June 30, 2016 07:00PM |
New board supports two Z motor connectors on board, no adapter needed. Have a look at the website, many questions answered there.Quote
Calvinx66
Hi Guys
The Vat thing is a very valid point, one that I didn't notice, I apologize.
@ Tony are you guys able to supply the 5v Daughter board ?
As I want to run two Z axis motors (P3Steel) without having to make an adapter myself !! (Being lazy I know)
Regards
Re: Duet WiFi details published, pre-order window open June 30, 2016 07:36PM |
Koko76
Re: Duet WiFi details published, pre-order window open July 01, 2016 03:22AM |
Re: Duet WiFi details published, pre-order window open July 01, 2016 06:42PM |
T3P3
Hi Calvin
No requirement for a 5v external board, the onboard BUCK circuit works fine.
For the Z motors in the 0.8.5 there is only one connector so you need to arrange to wire your Z motors in series(recommended) or in parallel with the wiring.
Cheers
Tony
Re: Duet WiFi details published, pre-order window open July 03, 2016 08:47AM |
Re: Duet WiFi details published, pre-order window open July 14, 2016 03:28PM |
Re: Duet WiFi details published, pre-order window open July 14, 2016 03:57PM |
Re: Duet WiFi details published, pre-order window open July 14, 2016 07:32PM |
Re: Duet WiFi details published, pre-order window open July 15, 2016 06:13AM |
