Duet 0.8.5 CPU Temperature June 20, 2016 10:45AM |
Re: Duet 0.8.5 CPU Temperature June 20, 2016 12:31PM |
yoorek
I just noticed that DWC started showing CPU Temperature (must be the latest 1.13a firmware version that did it). This is very useful :-)))))))
Question for other users - what temperature is it reporting for you and where is your Duet mounted?
Mine oscillates around 52 degrees centigrade and the Duet is mounted in the bottom part of the printed (like in David's delta).
@dc42 - what is the safe temperature range for Duet 0.8.5 CPU? I do have a fan blowing on the board as per your design. The other temperature sensor that I have placed below the heated bed on the bottom metal plate shows 38 degrees centigrade with the bed turned on and at 70 degrees. The reason I am asking is that I want to determine if I need to place another fan somewhere there to lower the temperature. Ambient temperature is around 21 degrees.
Re: Duet 0.8.5 CPU Temperature June 21, 2016 08:29AM |
Re: Duet 0.8.5 CPU Temperature June 21, 2016 10:04AM |
Re: Duet 0.8.5 CPU Temperature June 21, 2016 02:40PM |
DADIY
Is the 1.13a release stable and fixes the thermostatic fan, and does it support CPU temperature on Duet 0.6?
Re: Duet 0.8.5 CPU Temperature June 21, 2016 05:16PM |
