Wiring two nos of part cooling fan
Posted by selva_tvi
June 21, 2016 12:44AM
I am using DUET 0.6 board. I am planning to use two 40mm fans for PLA cooling. In the DUET board, only one set of pins are available for PLA cooling.
Shall I connect both the fans in parallel (connecting two red wires to +ve and two black wires to -ve). The fan is rated at 0.1A & 12V.
When i connect both the fans, will it get the maximum power(at 100% speed) to cool the prints?
Thanks
Selva
Re: Wiring two nos of part cooling fan
June 21, 2016 01:23AM
Yes, connect the two fans in parallel and you will get full power from both.
June 25, 2016 03:25AM
Thank you very much. It worked without any issues. And sorry for late reply..
