Extruder is not running
Posted by magier7
July 01, 2016 01:49PM
Hi
I've got a problem.
My extruders are not driven.
Although the temperature is reached
Maybe can someone help me
Re: Extruder is not running
July 01, 2016 02:35PM
Common causes of extruder not driven:
1. No tool selected. If you have just one print head with one extruder and one heater, send T0 to select it.
2. Tool heater(s) not up to temperature, and cold extrusion prevention hasn't been disabled.
July 02, 2016 01:10AM
i have 5 extruder 5 hotend
and have already been tested with T0, T1, -...
but all remain also Hotend was at 170 ° I heated as have tested it already with 190 ° and 210 ° no success
Edited 1 time(s). Last edit at 07/02/2016 01:37AM by magier7.
July 02, 2016 02:39AM
Please attach your config.g file so we can see what tool configuration you are using.
July 02, 2016 10:06AM
my config.g file
I've got yet another problem
the maximum wide ser software
not comply with the maximum possible wide agreement
possible wide at
x = 250 mm
y = 300 mm
z = 200 mm
Edited 1 time(s). Last edit at 07/02/2016 10:14AM by magier7.
open | download - config.g (4.5 KB)
July 02, 2016 10:47AM
This part of your config.g file is wrong:
;##### Extruder #####
M92 E1:660 ;Steps bei Extruder einstellen
M92 E2:660 ;Steps bei Extruder einstellen
M92 E3:660 ;Steps bei Extruder einstellen
M92 E4:660 ;Steps bei Extruder einstellen
M92 E5:660 ;Steps bei Extruder einstellen
Use this instead:
M92 E660:660:660:660:660
Also this:
M201 E0:500 ;Accelerations (mm/s^2)
M201 E1:500 ;Accelerations (mm/s^2)
M201 E2:500 ;Accelerations (mm/s^2)
M201 E3:500 ;Accelerations (mm/s^2)
M201 E4:500 ;Accelerations (mm/s^2)
use:
M203 E500:500:500:500:500
and similarly for your M201, M566 and M906 commands.
To tell the firmware the dimensions of your printer, use the M208 command.
July 02, 2016 11:41AM
spinning smiley sticking its tongue outthumbs up
thank you very nice
its going
